Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
2006 civic ac working intermittently
Old Apr 9, 2013 | 11:06 AM
Erasmus's Avatar
Default 2006 civic ac working intermittently
196k miles on this one-owner. Serpentine belt not replaced yet. Just oil changes and brake pads and tires. AC only cooling intermittently today. Any ideas?
Old Apr 11, 2013 | 08:51 PM
Hardedge's Avatar
Default Re: 2006 civic ac working intermittently
More info? When it does cool, is it cooling effectively? If so, it could be that the AC clutch isn't kicking on as often as it should. Usually the system won't turn on the compressor if it detects abnormally high pressure in the high side. One possibility is that your expansion valve is restricting more but still somewhat operating, and so the system will cool but then shut off as the pressure gets too high, and not switch on again until that pressure slowly bleeds off through the expansion valve. Or you could simply have intermittent operation in your AC clutch. In any case, AC work takes special equipment, so it probably won't be a DIY deal.
Old Apr 14, 2013 | 07:02 AM
Racer02gtstang's Avatar
Could also be relay or low on charge. We need more info. Humidity and temperature thru the day makes a big difference
Single-Cam
16
Feb 10, 2016 07:23 PM
CG01
Engine Management and Tuning
Nov 7, 2012 08:18 PM
Dman03GT
Jun 8, 2010 06:34 AM
KGNickl
May 1, 2008 01:59 PM
