cooling fan not turning on
Old Apr 9, 2013 | 10:38 AM
H0nda_Crazy's Avatar
Default cooling fan not turning on
Hey ht,
I have a 95 accord ex with an f22b1. I bought it without a radiator fan but picked one up at pick n pull and installed it. It doesnt turn on unless i turn the ac on. Anyone have any ideas about hiw i could have mixed up the wiring? The thermostat was replaced but not the coolant temperature sensor. Any help would be appreciated. Thank you.
Old Apr 9, 2013 | 11:20 AM
NZXTInerTia's Avatar
Default Re: cooling fan not turning on
The drivers side radiator fan should only turn on when AC is on.
As far as the passenger side main cooling fan read around for trouble shooting. They get messed up all the time.
Old Apr 9, 2013 | 12:42 PM
nus_dogg's Avatar
I would check the cooling fan relay.
Old Apr 9, 2013 | 04:22 PM
Lost Again's Avatar
Originally Posted by NZXTInerTia
The drivers side radiator fan should only turn on when AC is on. As far as the passenger side main cooling fan read around for trouble shooting. They get messed up all the time.
Sorry but that is WRONG information.
For any 3rd, 4th, 5th gen Accord.
Anytime the car is on - BOTH FANS SHOULD RUN !
The only time "one fan" runs is when the key is off.
EDIT: just for anyone reading, on the 6th gen - same applies when the car is On.....not when off.
Old Apr 9, 2013 | 09:09 PM
ReaperMan's Avatar
ikr. that is what i was thinking. my honda runs boths fans when on. and one with the car off.
Old Apr 9, 2013 | 09:42 PM
Huh, my AC fan only ever came on when my AC was on. Something must be up.
Old Apr 10, 2013 | 04:49 PM
Buzo209's Avatar
Changed the ECT but some other tube snapped off. Not sure how to upload pictures to post it. First day on here. The black connector thing is located right in front of the ECT. Anybody know what part I'm talking about?
Old Apr 10, 2013 | 05:14 PM
ReaperMan's Avatar
you mean the coolant temp sensor that reads the temp back to your gauge?
Old Apr 10, 2013 | 05:35 PM
Lost Again's Avatar
You have made some changes to your car so that "adds" a level.
My point, in a stock set up, BOTH fans run when the car/engine/KO and thermo a is working properly. If you need a wire diagram and help let me know.
Old Apr 10, 2013 | 05:49 PM
Buzo209's Avatar
Yea that one. That's what the dude at autozone recommended. Haven't seen if it worked yet. I accidentally disconnected some kind of connector that I can't quite put back on.
It the sane thing located in the picture in the forum link. The one with the red wire showing. https://honda-tech.com/forums/honda-accord-1990-2002-2/91-accord-f22a1-no-bottem-end-power-2801657/
Old Apr 10, 2013 | 10:14 PM
holmesnmanny's Avatar
that's the one you broke off...it's the "coolant temperature 'sender' "
Old Apr 11, 2013 | 08:54 AM
Buzo209's Avatar
How does it go back on?
Old Apr 11, 2013 | 10:39 AM
This is what we broke. How does it go back on?
Old Apr 11, 2013 | 01:03 PM
Mishako129's Avatar
It should just plug right in unless you broke the metal barb off in the sensor. On the wire end there should be a barb which snaps into the sensor.
Old Apr 11, 2013 | 01:54 PM
Buzo209's Avatar
The metal pin broke off too. We replaced that. And with the new engine coolant temp sensor, radiator fan still does not turn on. Next I was going to replace the radiator fan switch and see if that's the winner. We know that coolant is running through the entire system because both radiator hoses are hot.
Old Apr 11, 2013 | 02:57 PM
Mishako129's Avatar
What you need is the radiator fan switch which is located on the thermostat housing. You should jumper the cable for that switch and if your fans turn on then more than likely you need a new switch. Read this guide: http://techauto.awardspace.com/overh...ermoswitchtest
Here's a diagram of it,
Here is the part (fits my 91' accord),
Here's how to test it,
Step 1. Checking fan switch. Disconnect the radiator fan switch connector (a.k.a. thermoswitch, located downstream of the thermostat) and turn on the ignition, then jump (or short pins K and L ) on the harness (see figure 3.) Does the fan come on?
Yes.
-Coolant level low. (Only on cars with the fan switch not mounted on the bottom of the radiator.)
-Air not purge (go to step 4.)
-Thermostat stuck closed. Test the thermostat by boiling at Procedure 6.
-Thermister bad or giving false readings due to trapped air.
-Thermoswitch bad. Test the thermoswitch by boiling at Procedure 5.
-Water pump impeller missing caused by electrolysis. Open filler cap, water should flow with thermostat removed or when the engine is at operating temperature.
No. Check relay at step 2.
Old Apr 11, 2013 | 03:15 PM
Buzo209's Avatar
Will test tomorrow and let you know how it goes. Thanks for the help.
Old Apr 16, 2013 | 08:41 AM
Buzo209's Avatar
So we used jumper wires to the radiator fan switch connector and the fan kicked on. So we replaced the switch. But the fan still doesn't kick on when it gets hot.
Old Apr 16, 2013 | 09:05 AM
ReaperMan's Avatar
here are the possibilities. defective switch. wrong switch. or coolant not bled right.
Old Apr 16, 2013 | 09:06 AM
Buzo209's Avatar
We have replaced the coolant temperature sensor and the radiator fan switch already.
Old Apr 16, 2013 | 10:03 AM
Using this illustration describe which part numbers you have replaced and where you bought them and part number plz
also is your car overheating ? it could just be it's not getting hot enough yet
http://www.hondapartscheap.com/parts...er-pump-sensor
did you properly bleed your car ? Is the thermostat jiggle valve facing the sky ?
Old Apr 16, 2013 | 10:31 AM
Buzo209's Avatar
Replaced number 16 and 19 on the diagram. After I replace 19 a bled and filled the coolant. When I replaced 16 no coolant spilled out but it was visible. I bought them both at autozone
Old Apr 16, 2013 | 10:32 AM
Buzo209's Avatar
Car does overheat when it sits and us running
Old Apr 16, 2013 | 04:12 PM
Swap a door relay in for the fan relay and see what happens.
Old Apr 16, 2013 | 04:20 PM
Buzo209's Avatar
The fan does turn on when I shut the ignition off. But dies not turn on when the car is running
