Intake cam degree, head milling, ignition timing help
Old Apr 9, 2013 | 09:08 AM
preludewillie's Avatar
Default Intake cam degree, head milling, ignition timing help
I've been checking around, but can't seem to get a solid answer for my question. I have an ls with pr3 pistons and delta 272 cams. Head has been milled .030. I recently degreed the cams. I ended up with +2.5 on the exhaust cam, and -4 on the intake cam. Before taking it to get street tuned (car will never see the dyno), I decided to double check my ignition timing. I did everything as far as the basics are concerned. Jumped the service check connector, operating temp, even unplugged the iacv since the idle was set a little higher to keep the engine from stalling when the cams were first installed. With the head being milled, and the cam @ -4 degrees, I can't get enough adjustment out f the distributor. To get it to run without ******* from a stop, it's all the way advanced, and it looks to be about 15 degrees. So here are my questions:
Is this common?
Is my new base ignition timing actually 24 degrees for the amount of intake retard? (2 degrees ign for every 1 on the cam gear)
Do I leave the distributor all the way advanced where it is now, and have my tuner add the extra (approx) 9 degrees across the board to get from 15 to 24?
Other cams have not had this much adjustment before, so I've never encountered this. Thank you!
Old Apr 9, 2013 | 11:00 AM
odz-fab's Avatar
Default Re: Intake cam degree, head milling, ignition timing help
if distributer is maxed out with adjustment than add or subtract x amount of total timing in your timing maps to so that you true timing for your tune is on point. make a note of what the timing change was so that future changes can be reversed if distributer adjustment can corrected.
Old Apr 9, 2013 | 01:54 PM
cruizinmax's Avatar
You set the base timing at 16 degrees, no other calculations. You are only 1 degree retarded from where it should be.
Old Apr 9, 2013 | 10:23 PM
raverx3m's Avatar
if you are using a remanufactured dizzy thats what you get most of the time. they are not calibrated properly and max out with stock settings giving you no play.
i had exact same issue when dynoed my car first time
bluedlude
Nov 9, 2006 06:31 AM
vspec12
May 24, 2004 10:50 AM
JDMs1eeper
18
Aug 24, 2003 12:01 AM
Edwin
Jul 17, 2002 05:58 AM
iperez
Feb 19, 2002 10:10 AM
