plasti-dip WHAT A MESS
Old Apr 9, 2013 | 08:27 AM
sleepyaccord96's Avatar
Default plasti-dip WHAT A MESS
I got a set of Rota HM3's....BUT unfortunately they have been plasti dipped almost 3 times with 3 different covers and with spray paint...i have used half gallon of paint stripper "kleen strip aircraft remover".. Cant seem to get this garbage off the wheels...Any suggestions? preferably from someone who has experience with removing plasti DIP?
Old Apr 9, 2013 | 10:27 AM
Dangjohn's Avatar
Default Re: plasti-dip WHAT A MESS
I've removed plasti dip with goo gone. I have the spray bottle. Let it sit for a while then I used a microfiber cloth to wipe off. I dont know if it will work since you said you tried aircraft stripper. But give it a try. Try using goo gone on the plasti dip first then Use the aircraft stripper on the spray paint. Gl
Old Apr 9, 2013 | 10:52 AM
cvcrcr99's Avatar
Yes. You are supposed to peel it off, thus the craze for it. I guess you tried that? I hate PD btw
Old Apr 9, 2013 | 11:16 AM
it doesn't peel off in all areas...
I have a full set of rota HM3's and they are such nice wheels with this junk stuck all over them!
I just went and had the tires taken off the wheels so i can move em around a bit easier and maybe have a better time removing this crap.
Old Apr 9, 2013 | 12:45 PM
TunerN00b's Avatar
Why would you use chemical paint stripper on a rubberized plastic coating?
Use the correct tools.
Old Apr 9, 2013 | 01:20 PM
TypeRfit's Avatar
RESIDENT
They have posted videos before that once someone paints over Plastidip that it becomes a pain in the *** to remove. Above poster gave the best idea
Old Apr 9, 2013 | 08:22 PM
Dangjohn's Avatar
Is the plastidip over the spray paint?
Old Apr 10, 2013 | 05:35 AM
ok they are rota hm3's
They are originally black wheels with a polished lip, it goes as followed... red plasti dipm clear PD, white PD, then followed by yellow PD, then spray painted black.
I used paint remover to get the black off so i can access the 25 layers of PD.
I got one wheel down to Bare metal using a commercial grade Hot water pressure washer. After using the pressure washer on it and all the paint remover it messed the original black off the rota, so i took it down to bare metal. I get to use the guys hot washer on thursday again so i am going to have the other 2 tires taken off the other two wheels and get started on them.
I will try to use some wire wheels i just dont want to damage the wheels
Old Apr 10, 2013 | 05:39 AM
OGxruiner's Avatar
the problem seems like the spraypaint OVER the PD. i'm sure there was some sort of chemical reaction that occurred and probably hardened the PD.
have you tried straight heat yet?
Old Apr 11, 2013 | 06:24 PM
Dangjohn's Avatar
Were u able to remove it all off?
Old Apr 12, 2013 | 07:36 AM
well i have completely Stripped one wheel all the way down to bare metal. Like i said above the wheels were originally black with polished lip and unfortunately through all the heat from the diesel powered hot water pressure washer and all the paint stripper i lost all the black so the one wheel is completely stripped of all paint and PD.
I am lucky i found one of my customers have this huge pressure washer the size of my civic hatch which is what i used a few days ago to get this all started. but i am unable to use it right now cause he is out of town, but monday i will go back to his place and take the other 3 and get as much as i can off. I have over 3 1/2 hours involved in 1 wheel and luckily it is done. While i am waiting til monday i have been brushing on thick layers of stripped on the wheels and it seems to make it lift off a bit which is helping get them prepped for using the pressure washer on them, so that way i am not using his PW machine for 6 hours lol.
off topic, i got a new digi camera that i am waiting on a charger for it so once it comes in i will post pics of what i am working with. will update with pics asap
Old Apr 12, 2013 | 07:38 AM
i have not tried just heat... i will try it tonight though.
Old Apr 15, 2013 | 11:26 AM
i got a new camera and i took pics so you guys can see why to never plasti dip wheels, let alone a whole car! bare with me...will have pics up in 3 hrs.
Old Apr 15, 2013 | 03:27 PM
ej1 rep's Avatar
Aircraft remover would have that **** gone in a jiffy. Im not a fan of Plasti-dip but I think it loses its removal quality after that many layers, and sounds like some spray paint too. But yeah that stuff sucks, wheels probably really suck because of all the nooks and crannies.
Old Apr 15, 2013 | 04:48 PM
this is the 4th wheel i am fighting with...it is the worst one so far, i do however have 3 of them done and finished...after 9 1/2 hours of labor
here is 2 i have done already
still a lil bits here and there i gotta get off but i am still working it!
Old Apr 17, 2013 | 10:00 AM
finished with them and they're going on the car tmrw!
Old Apr 17, 2013 | 10:08 AM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
why not repaint the black first? use the self etching primer first to make sure the paint sticks solid
Old Apr 19, 2013 | 12:25 PM
ehhh idk, i kinda like em bare!
Old Apr 19, 2013 | 02:14 PM
grumblemarc's Avatar
The Grumpiest
Polish them or have them polished.
Old Apr 19, 2013 | 06:03 PM
808zrk's Avatar
Polished wheels are sick, but they are a pita to maintain
Old Apr 19, 2013 | 06:09 PM
FABEL's Avatar
glad you stayed dedicated to bringing these things back to the respected level they deserve.
Old Apr 19, 2013 | 07:45 PM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
Amazing!!! He can speak and not just post pics of a pos.
Old Apr 20, 2013 | 04:42 AM
i got them on the car! fronts are rubbing just a bit..gotta adjust the camber.
They look great but my tires look dumb. will post pics today
eyeAMthe1
Jun 23, 2012 04:43 AM
infamouskillas
Paint and Body
May 11, 2008 08:56 PM
slammedEM1Si
Apr 8, 2007 12:10 PM
4U2NV
May 27, 2005 09:07 AM
