Eg hatch electrical problem
Old Apr 8, 2013 | 07:42 PM
Hyunbs's Avatar
Default Eg hatch electrical problem
Hey there HT, ive been having a electrical issue in my 94 hatch si. Okay here it goes. Everytime I have the car on and I turn my headlight **** once, my dash comes on and everything is normal, but when I turn it once more to turn my head lights on, my clock, dash, ac lights, all are dim... I have a after market radio in my car and my dash fuse blew everytime And I fixed that tho, the illumination wire was bare so i tapped it off with electric tapeand the fuse didnt blow and my radio was fine, any help is aawesome! And i did do my research and all I found was "fuses" i already swapped out ALL my fueses... Also i can post pics of anything you guys need to see!
Old Apr 9, 2013 | 01:43 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: Eg hatch electrical problem
If the fuse still keeps blowing, there's a short/grounded wire somewhere. Could also be a bad headlight stalk switch or dimmer slider switch.
Old Apr 9, 2013 | 02:08 AM
jbpnoman's Avatar
The illumination wire was bare on which side of the harness? Is it attached to your deck? I'd lean towards needing a new switch.
Old Apr 9, 2013 | 09:41 AM
EgNoobCx's Avatar
have you tried using the dimmer switch to increase the brightness?
if not then i lean towards the switch being bad or short somewhere
Old Apr 9, 2013 | 09:48 AM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Did this problem also happen *before* the installation of the radio / head unit?
Old Apr 9, 2013 | 10:10 AM
HDSlo...GUY's Avatar
I am pretty sure the clock is suppose to dim when the head lights are turned on. What type of head unit did you install?
Old Apr 9, 2013 | 10:16 AM
deschlong's Avatar
Loved
Community Favorite
^ Clock dims with parking lights. OP is suggesting that the clock dims only when headlights are on, plus all sorts of other stuff on the dash that *isn't* supposed to dim.
Old Apr 9, 2013 | 11:42 AM
Former User's Avatar
Has the battery and alternator been tested?
Old Apr 9, 2013 | 12:05 PM
Hyunbs's Avatar
This happened before I installed a radio, brand new battery was put in a couple of days ago (my old battery wasnt holding a charge) alternator was checked at autozone and is good. And the illumination wire is the one that is on the radio harness im guessing. I will post a picture, my dimmer switch works fine , I can turn it up and down and I see my dash getting brighter and dimmer, unless its not strong enough haha. Should I change the dimmer switch? Where are the common grounds that can cause this? My radios ground is hooked up to the harness. My radio is a pioneer deh 2000mp
Old Apr 9, 2013 | 12:06 PM
Hyunbs's Avatar
By dash i meant my cluster
Old Apr 9, 2013 | 12:22 PM
Hyunbs's Avatar
Also is it normal for the clock and ac lights to dim when the headlight switch is turned once and twice? Sorry, its my first car and never owned a honda lol. Went from driving my parents lexus to this hatch so bare with me
Old Apr 9, 2013 | 12:24 PM
Yes
Old Apr 9, 2013 | 03:00 PM
Hyunbs's Avatar
Originally Posted by RonJ@HT
Yes
Oh okok, like really really dim though? Like to the point where I can barely see the clock
Old Apr 9, 2013 | 03:02 PM
deschlong's Avatar
Loved
Community Favorite
If it's daylight out, then yes. If it's dark out and you still can't see them, then no.
Old Apr 9, 2013 | 09:16 PM
Hyunbs's Avatar
Ok thanks
Old Apr 10, 2013 | 08:55 AM
Hyunbs's Avatar
Okay so i fixed the fuse problem! It was one of the radios wires that was touching metal. But now i justt noticed the little green led on my cruise control and fog light seitch doesnt come on when pressed. The words cruise and the fog light logo comes on though.... Any ideas?
SKAVENGER88
Feb 13, 2012 12:12 PM
chrisff521
Mar 6, 2010 08:02 PM
mrmagic0097
12
Feb 18, 2009 01:46 PM
dc5itracer
14
Oct 26, 2008 01:21 PM
deadeyehatch
Nov 20, 2003 11:44 AM
