Tucson, AZ 91 CRX b18c part out
I have tons of stuff off of a 91 CRX for sale. Lots of aftermarket goodies as well. If you dont see it, email or text me if I have it and I will respond within a few mins most likely.
ALL PRICES ARE OBO!!
1998 JDM B18C not USDM B18C1 -$3000
Head was rebuilt with
SBI Chrome Plated Valves
SBI Bronze Valve Guides
Fel Pro MLS Head Gasgket
ARP Headstuds
New OEM Timing Belt
New OEM Water Pump
New OEM Oil Pump
Helical LSD S80 5 Speed
Innovative Mounts -$300
Innovative Shift Linkage -$100
Halfsize radiator -$100
Rywire Engine harness-$500
Chipped P72 ECU - $100
Full Set of GlowShift Gauges -$400
-Speedo
-Tach
-A/F Ratio
-Boost/ Vacuum
-Volt Meter
-Fuel Level
-Water temp
-Oil Pressure
Aeromotive Fuel Pressure Regulator-$100
Golden Eagle Mfg Fuel Rail -$100
Aeromotive 340 lph Fuel Pump -$120
Koni Sport Yellow Shocks and Struts -$550
Ground Control Sleeves -$300
Eibach Springs 250 Front / 450 Rear
Black Works Racing LCAs -$180
92 Integra Big Front Brake Swap 10.5 inch Rotors and knuckles/hubs -$300
89 CRX Si Rear Disc Brake Swap -$250
89 CRX Si Rear Sway Bar -$50
Extended Top Hats -$75
6 Point Rollcage with rear strut brace -$1500 in car now...
Full Race Traction Bar -$300
Racing Seats - $100 each
Carbon Fiber Hood -$100
Stock Front and Rear Si Bumpers -$200 each
Enkei RF-1 17x7 Rims -$400 with new tires
Stock CRX Tail lights - $200
Black Altezza Tail lights -$100
Black Projection Headlights -$100
Black Turn Signal lights -$50
Black Running Lights - $60
Stock Steering Wheel - $25
Stock Under dash Fuse box -$20
Stock Engine Bay Fuse box - $20
Call / text at 415-350-91five0
ARP Headstuds
New OEM Timing Belt
New OEM Water Pump
New OEM Oil Pump
-Speedo
-Tach
-A/F Ratio
-Boost/ Vacuum
-Volt Meter
-Fuel Level
-Water temp
-Oil Pressure
