Transmission & Drivetrain Gearboxes, Differentials, Clutches
3rd grind in LS trans
Old Apr 8, 2013 | 06:11 AM
egcoupekid's Avatar
Icon2 3rd grind in LS trans
how's it goin everybody, me and my buds did an LS swap in my eg coupe and i was unaware that we didnt put trans fluid in and i drove it to autozone and back (6 miles total) now my 3rd gear grind whenever i shift into it above 3500rpm from 2nd and this is only when i upshift, im hoping its just the syncro... its a LS transmission to.
Old Apr 9, 2013 | 11:09 AM
DelSol-B18's Avatar
Default Re: 3rd grind in LS trans
Try running a syncromesh. See if that helps with the grind
Old Apr 9, 2013 | 11:12 AM
DelSol-B18's Avatar
Also how do you know that it didnt grind before you put it in??
Old Apr 9, 2013 | 11:18 AM
DelSol-B18's Avatar
Also, i have a b16 trans that doesnt grind or have any popouts shifts fabulous! Its an S4C hydro id let go for $400. Im also located in Ohio, Toledo. Pm me if interested. It would make your LS scream with the shorter gears!!
Old Apr 9, 2013 | 01:42 PM
redyute's Avatar
Exactly running the trans dry would damage bearings before synchro's
Old Apr 15, 2013 | 05:32 AM
egcoupekid's Avatar
it was a flawless trans when i bought it. and how bad is it to drive it with that grind till it gets real bad? its my daily
Old Apr 16, 2013 | 09:40 AM
GagnarTheUnruly's Avatar
Try different ways of getting through the gate. Mine is notchy if I push too far to the right as I'm going into 3rd. If I go straight up out of neutral it's fine. I think the bracket on my shift linkage may have bent slightly when I did my swap.
Stopsign32v
Aug 8, 2019 05:44 AM
UndisputedH22a
May 6, 2010 08:11 AM
shocker911
Dec 24, 2008 03:52 PM
hybridpatient95
14
Apr 7, 2005 04:47 AM
