Honda Crx battery Dying
I have a 1990 Honda Crx Hf model. The Battery Recently started Dying. I Origianlly thought it was my Alternator Since I have had to replace it before. It has a Brand New Battery, New Ground lead for the Battery, and a new connector for the positive terminal. After riping out the alternator and taking down to nappa, they tested it and it was putting out perfect volatage. So I brought it home and put it back in. This was tuesday. Wednesday it was working perfectly. It worked fine, putting out perfect voltage till today, which is sunday. I have tested it multiple times and maximum voltage that is being pushed it about 12.5 volts. I can't figure out what the issue seems to be. My step father mentioned something about a volatge regulator relay. Help would be amazing. I have a 5 day a week job Kinda need to make it there.
12.6volts is average for a battery when the key/engine/everything is turned off. 12.5v is not a problem.
If you have 12.5volts while the engine is running, it sounds like an intermittent problem with the charging system. Alternators put out over 13v (minimum) while the engine is running.
crj_lll
Nov 8, 2005 09:32 AM
Cryptopsy
Aug 13, 2005 04:04 PM
