Jdm 98spec itr swap FS
Old Apr 7, 2013 | 04:56 PM
spoolinfool's Avatar
Default Jdm 98spec itr swap FS
I have a 98 jdm itr swap forsale for 2800.The engine was purchased at n1concepts and I can give the buyer a copy of that receipt also if needed. I estimate that the swap had anywhere from 45-60k on it when I purchased it based on the condition of the clutch assembly and afew other components .I put on less than 15K miles on it before pulling it out due to a smog hookup getting busted, therefore I could not smog it in time to renew my sticker.This engine does not burn any oil or smoke and the transmission shifts like new.This swap has been well taken care of.I did a leak down test before pulling it and numbers were all below 5% on the engine warm.Below is a list of everything that's included in the sale and a list of items that were changed as a part of routine maintenance prior to swapping it in.
The swap includes:
98 spec itr engine and 4.7 final drive ne3 transmssion and engine harness for eg/dc
itr shift linkage and shifter(painted black with es energy bushings)
All axles and mounts
Usdm throttle cable(Purchased new)
Buddyclub header (purchased new)
p28 ecu with stock jdm itr program(phearable.net)
Parts that have been replaced:
Action 1ks clutch kit(purchased new)
Fidanza Aluminum 7lb flywheel(purchased new)
rear main seal(acura oem)
Distributor cap and rotor(acura oem)
thermostat(acura oem)
timing belt with tensioner and spring and waterpump(oem acura)
upper radiator hose( goodyear)
I might be forgetting other items changed.Below are pics of the swap,its wrapped up and ready for the buyer.
Old Apr 8, 2013 | 07:10 PM
champ-white-boy's Avatar
Default Re: Jdm 98spec itr swap FS
wow good price
Old Apr 9, 2013 | 01:28 PM
ludicrous's Avatar
Hey, I messaged you about the swap...hit me back up
thanks
Old Apr 10, 2013 | 04:04 PM
Swap is sold! Moderaters please close.
Old Apr 14, 2013 | 08:47 PM
supremeXorio's Avatar
Damn
ef9sirhatch
Northern California (Sales)
Jan 14, 2013 09:58 PM
IllfadedSol
Nov 27, 2008 10:30 PM
MaGoodc2
11
Jun 27, 2005 11:58 AM
Evs-One
Dec 16, 2003 10:37 PM
