New Transmission How Much Fluid??
Old Apr 6, 2013 | 12:19 PM
jmh4bb6's Avatar
Default New Transmission How Much Fluid??
Im replacing the tranny in my prelude soon and need to know how many quarts of atf I need! I know to flush it i need about 2 quarts. Its also an auto. Any help is appreciated!
Old Apr 6, 2013 | 01:44 PM
P. Hunter's Avatar
Default Re: New Transmission How Much Fluid??
well when you got the trans im sure the torque converter came with fluid in it BUTTTT you can always make sure of it.. after you fill the trans check to see the level. make sure its full. jack the car up so the wheels are off the ground and get trans to go into full lock up (have it shift through all the gears), this will get the fluid to get into the converter. check the fluid again and see if you need to add any
Old Apr 6, 2013 | 06:01 PM
Apex1972's Avatar
manual swap
jmanuel
Apr 24, 2014 09:48 PM
hamadiscool
Honda Civic (2001 - 2005)
Jun 5, 2007 08:21 PM
St3v3
Feb 11, 2007 05:09 PM
Cypher0117
May 3, 2005 06:47 PM
mystikz2002
Acura TL, RL & ZDX
12
Jan 20, 2005 09:22 AM
