Intake Manifolds suggestions
In the process of collecting all my parts. But the engine stats are as followed.
1) B18c1 block
2) LS crank 89mm
3) Eagle rods
4) CP pistons 81.5mm 12-12.5:1 compression
5) GSR ported head (port flow/4pistons)
6)upgraded valve train.
7)skunk2 pro 2 cams
But trying to determine what intake manifold would suite this build the best.
1) B18c1 block
2) LS crank 89mm
3) Eagle rods
7)skunk2 pro 2 cams
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/all-motor-forum-%5Bfaq%5D-2628364/
Check out the many topics there discussing different manifolds and manifold dyno testing. If you have any specific questions after reading through those topics, then ask.
hondaapi
Apr 29, 2006 05:13 PM
slodel
Mar 8, 2005 07:59 PM
