Intake Manifold Porting
OP, those manifolds look fine. I am a fan of your second pick more so than the first.
i thought when they bench test the porting they test each individual runner no?
OEM manifolds dont flow exactly same but almost everyone knows it by now and some tuners adjust individual cylinder trim to make up for that.
Having the runners/ports flow exactly the same is not the end all be all. There's a certain a amount of room for variance before it really matters.
No, because the B16 has smaller runners. Even ported are probably a bit smaller than an ITR or PX. Ported needs to be done so the motors don't choke above 7500 and the purpose of the B16 is for torque earlier. More plenum volume I'm sure would help with upper RPM's.
Sorry no Before Pics i feel dumb that jumped the gun with my makita and didnt take some shots
I was between AEBS/PerfX in the start then i thought about that P30 i had laying around so i decided to port it. I wanted to do it myself so i can see first hand whats involved in the process and tbf it'll be a huge morale boost if it makes Decent power over my previous manifold
I'm porting mine and i took before & after pictures mainly for a visual point of referrence.
Doesn't look nearly as good as you porting but I'm not to picky on surface area rather than the shape.
in for the results.
in for the results.
Yeah sorry for not updating. I Installed the IM along with a 70mm TB, and i havent dynoed yet. But when i tuned my car since i was planning on doing multiple changes soonish, we had redline afr aprox 11:1 so it wouldn't lean out. I retuned couple of days ago and AFRs where at 12.8:1. So it Definatly picked up Power how much i cannot say. Car picked up immense midrange and it accelerates far harder on part throttle. that's all i noticed sorry for the lack of dyno time
