94cx Not turning over. need help diagnosing.
Old Apr 5, 2013 | 01:18 AM
MShonda's Avatar
Default 94cx Not turning over. need help diagnosing.
I have a 94 cx hatch with a OBD1 b18b1 swap.
I work offshore so the car has been sitting for 4 weeks, it ran perfectly when i parked it.
~what it is doing....
when I put the key in the on/run position the dash lights come on ( check engine light comes on then goes away) the radio comes on like normal and i can hear the fuel pump priming. However when i turn the key to start... I hear a click (guessing the starter relay) and then nothing.
~ what i have done.
prior to parking it for 4 weeks, i just put in a new battery, starter, and clutch switch. so i highly doubt those are the case.
i swapped in a known good main fuel relay and nothing changed.
i swapped in a known good ecu and nothing changed.
what does this sound like? any help would be appreciated.
Old Apr 5, 2013 | 02:41 AM
d15bvtechatch's Avatar
Default Re: 94cx Not turning over. need help diagnosing.
its the rubber grommet on the back of your cluitch pedal busted and is not engaging the clutch switch.
Old Apr 5, 2013 | 02:57 AM
MShonda's Avatar
I have replaced the rubber grommet with a penny superglued to the pedal, I have had to replace many of those before. I also double checked to see if that was still in place, which it was.
Old Apr 5, 2013 | 03:45 AM
MShonda's Avatar
Let me ask this question. The car was sitting up for 4 weeks. If the battery is low/weak, will it allow for all interior lights/radio and prime fuel pump as normal when the key is turned and then when you try to crank... Do nothing?
Old Apr 5, 2013 | 04:44 AM
Former User's Avatar
The main relay and ECU have nothing to do with the starter circuit, so swapping those led to the expected outcome.
Test/Charge the battery and go from there.
alex1320
26
May 27, 2014 07:08 AM
magicmyst98
14
Sep 2, 2013 12:06 PM
zerovandez
Apr 1, 2011 01:05 PM
B16COUPE94@AIM.COM
Feb 18, 2008 05:43 PM
ateggy1
Feb 17, 2008 04:58 PM
