Honda Civic 98 EX Window keeps falling of track!
Old Apr 4, 2013 | 05:12 PM
Patryk_98's Avatar
Default Honda Civic 98 EX Window keeps falling of track!
My drive side window on my 98 Honda civic Coupe keeps falling off, I have tried to replace the regulator twice now with no luck.
Any suggestions?
Old Apr 4, 2013 | 05:26 PM
vitamin_c95's Avatar
Default Re: Honda Civic 98 EX Window keeps falling of track!
My EG is the same. Yet to figure out mine. Hows the track look?
Old Apr 4, 2013 | 05:57 PM
Former User's Avatar
Align the glass as per service manual and spray some silicone lubricant into the rubber side tracks so the glass slides smoothly.
Old Apr 4, 2013 | 08:40 PM
Pistonman's Avatar
If the regulator is not bent, and the channel looks good, spray the channel with dry silicone lube as said above...AND... On the regulator kicker ( the floater arm near the bottom with 2 bolts in it) take out the rear bolt and loosen the front(the rear hole is slotted) use a rattail file to elongate the hole towards the bottom 3/8" to 1/2". Put the bolt back in, and hold the arm to the bottom of the hole and tighten the bolts.
Osbjoey
Jul 6, 2013 10:56 AM
98EKEX
12
Nov 3, 2012 06:19 PM
98Sdime
Apr 10, 2010 10:29 AM
mugenfoolex98
Oct 9, 2005 03:30 PM
