Are there any remote kill switches for fuel pumps out there
I know a lot of people have kill switches for their fuel pumps but I was looking into something that I could do remotely (ie not while I'm at the car). Anyone know of any companies out there doing solutions like this.
Those have a distance limitation though, what I was speaking of is something that could shut off the fuel pump from anywhere.
dei has there car*com unit. it works from a phone and uses cell phone towers to control the alarm. check out directed.com
why would you want to do this? if its so no one can see you hit the swtich, you could always tap off the Armed/starter kill output wire, hook it to your fuel pump ground wire and your done. Alarm on, pump disabled, alarm off, pump enabled.
-Rage
-Rage
....ap off the Armed/starter kill output wire, hook it to your fuel pump ground wire and your done. Alarm on, pump disabled, alarm off, pump enabled.
-Rage
-Rage
why would you want to do this? if its so no one can see you hit the swtich, you could always tap off the Armed/starter kill output wire, hook it to your fuel pump ground wire and your done. -Rage
I cant find a ground wire for my fuel punp anywhere, i have an 88 civic.
I'm starting to think that the fuel pump grounds itself, so that as long as the fuel pump is toughing metal(gas tank) itll ground through there. so its like a self ground.
any idea if there even is a ground?
laoboisosilly
Audio / Security / Video
Feb 17, 2009 05:23 PM
