what clutch/pressure plate are you guys using?
Old Oct 22, 2002 | 01:40 PM
Accord15's Avatar
Default what clutch/pressure plate are you guys using?
I know this topic has been beaten to the ground. There is way to many posts and they all say something different, its pretty overwelming. I need a new clutch my centerforce dual friction has messed up the main shaft bearing (the car does not want to go into gear) I am assuming no way to really tell with out pulling the trans off. So i need a clutch that will pull pretty hard but not screw up any bearings in the transmission. Trying to get into road racing pretty soon so i want something that can handle that abuse. Thanks
Old Oct 22, 2002 | 01:51 PM
Accord94DX's Avatar
Default Re: what clutch/pressure plate are you guys using? (Accord15)
ACT Xtreme Pressure Plate with Street disc. "XTSS"
I it.
Best clutch evAr!!
Old Oct 22, 2002 | 01:59 PM
niedejb's Avatar
Default Re: what clutch/pressure plate are you guys using? (Accord94DX)
Same
Old Oct 22, 2002 | 02:08 PM
Nick M's Avatar
Default Re: what clutch/pressure plate are you guys using? (niedejb)
"HDSS"
Heavy Duty Pressure Plate and Street/Strip disk
I like it.
Old Oct 22, 2002 | 02:36 PM
smokin rubber's Avatar
Default Re: what clutch/pressure plate are you guys using? (Nick M)
CM stage 1
so far so good
Old Oct 22, 2002 | 03:00 PM
Accord15's Avatar
Default Re: what clutch/pressure plate are you guys using? (smokin rubber)
I'm guessing no one has any bearing problems with any of these set ups right?
Old Oct 22, 2002 | 03:21 PM
Accord94DX's Avatar
nope
Old Oct 22, 2002 | 03:49 PM
niedejb's Avatar
Which bearings? Throw out? Crank bearings? Rod bearings?
Muffler bearings?
Old Oct 22, 2002 | 04:38 PM
90AccordEX4Dr's Avatar
New User
ACT Heavy Duty Pressure Plate w/ Hybrid Street Disc
Very happy with the set-up.
Old Oct 22, 2002 | 06:38 PM
Accord15's Avatar
the large ball bearings on the main shaft and the countershaft. I was told the centerforce dual friction grabs so hard it can cause a "shock" or bad vibration on the main shaft and the countershaft causing these bearings to go bad. Muffler bearings are still good thank god they are a bitch to get to
Old Oct 22, 2002 | 06:43 PM
niedejb's Avatar
Mainshaft? You mean crankshaft?
Countershaft? You mean balancing rods?
Need a translator.
Reason I'm asking is there are no ball bearing on either. If youre talking axles...yeah. Just trying to decipher what you mean.
[Modified by niedejb, 9:44 PM 10/22/2002]
Old Oct 22, 2002 | 08:21 PM
ratherbewalking's Avatar
hdr6 (act of course)
Old Oct 22, 2002 | 08:25 PM
CD8's Avatar
CD8
Default Re: what clutch/pressure plate are you guys using? (ratherbewalking)
ditto.
Old Oct 22, 2002 | 10:39 PM
Accord15's Avatar
sorry can't think of any way of explaining it i am looking at the diagram right here and there is a ball bearing on the main shaft of the transmission and a ball bearing on the counter shaft. I am assuming it is these bearings. I was told by a dude at a transmission shop and he was talking about the same bearings. oh well i am goin in there tomorrow to talk to him i will ask if he was talking about these bearings.
Old Oct 23, 2002 | 08:59 AM
p0pe's Avatar
Anyone here install it themselves? If so how hard is it (with help from helms of course)? I think mine is going out and I might attempt it.
Old Oct 23, 2002 | 09:05 AM
GimpyAccord's Avatar
are you talking about the pilot bearing??? thats the only bearing in that region (besides the throwout bearing) i can think of. The transmission input shaft slides into it. Its inside a recess of the crankshaft. Its not a ball bearing unit though.. it uses needle bearings. what it does is keep the input shaft of the transmission centered and play-free.. so to speak.
edit: do Accords even have a pilot bearing or bushing???? I dont remember its been a long time.... I looked on hondaautomotiveparts.com and cant find one. I'm pretty sure they dont. I don't remember putting one in my car from the clutch kit when i swapped 3 years ago.
if you bust up your pilot bearing (if so equiped) you'll hear a howl etc ... its not too pretty. it would also allow the inputshaft to wobble causing some severe tranny fuckery.
[Modified by GimpyAccord, 10:21 AM 10/23/2002]
Old Oct 23, 2002 | 09:33 AM
Howitt's Avatar
Default Re: what clutch/pressure plate are you guys using? (GimpyAccord)
I gotta order my action clutch from rocket here soon mine is dying and gotta get funds
Old Oct 23, 2002 | 11:58 AM
Accord94DX's Avatar
n0p3. n0 p|LOt b3AriNg |n AkOaRDZ
Old Oct 23, 2002 | 01:21 PM
Accord15's Avatar
i am just confusing everyone so i give up i am looking at my helms right here and i would show everyone what i am talking about. This is for an h22 the sections i am looking at are 13-18 and 13-23. If any one has a helms for a prelude check it out and explain what i can not. It doesn't matter anyway i just wanted clutch info. Sorry for the confusion
Old Oct 23, 2002 | 01:24 PM
SOHCArchangel's Avatar
had: clutchbastards stage IV
have clutchbastards stage III
turbosivtec
Feb 8, 2009 02:26 PM
eg customs
Nov 7, 2008 09:28 AM
nanagsr
Jun 15, 2008 05:10 AM
Doc.
18
May 26, 2004 02:10 PM
stupidfast
Dec 11, 2002 03:58 PM
