k20a2 800 whp turbo part out
Old Apr 3, 2013 | 10:27 AM
xbigpitax's Avatar
Default k20a2 800 whp turbo part out
as some may know me from Miami . I have an eg coupe with a kseries turbo that's been a blast but time to let go .. complete setup will be sold .car has only been ran at 21 psi which made 630.
everything bought new................. 786 600 8022
engine. k20a2 prb-1 head
three angle vavle job
supertech vavletrain 95lb
supertech dished comp vavles
supertech 7 degree keepers
brain crower stage 2 all motor cams
oem head gasket
arp headstuds
new prb oil pump
11:3:1 je pro pistons with je pro rings fresh hone 86 mm stock bore
eagle rods
oem crank
everything was balanced motor sounds stock mint conition has 1100 miles .
rbc stock tb will be included this is literally a complete drop in long block can be used all motor/nitrous or turbo . this will make 250whp all motor this is a complete motor drop right in
$ 4500.00
complete full v band turbo kit
6466 precision turbo . has an 11 blade gtx wheel it actually picked up on same boost from 558 to 619 gtx billet 11 blade wheel was 500 alone
fabworks manifold dual 44 mm gates
two brand new tial44 top black bottom crome
brand new tial 50 mm q
all intercooler piping for eg/dc all black compler 4 ply and clamps
back door setup intercooler
iat welded to pipe intake pipe from locash.
all v band down pipe
two dump tubes
turbo lines all russle
my setup is super clean efficient and flys . I only rev it to 9000
$3,600
2004 ep3 trans with
1-2 gear base model rsx
3-5 ep3
4.7 final with
oem 2011 lsd
trans has literally 27 k bought at junk clean
$1000. comes with half shaft
ID 2000 injectors mintthe best ive ever owned
$ 650.00
I have a lot of vouchs this motor was tuned by fred in florida sick tunner car hasnet never had a hiccup ...
compition twin disc mint works perfect
$ 650.00
prices are pretty firm I will listen to reasonable offers ..best thing is anyone can see car running I can face time with anyone before part out...
20 psi
nycek9
Mar 28, 2012 01:39 PM
allmotorh22
Apr 12, 2007 01:37 PM
allmotorh22
Mid-Atlantic (Sales)
Jan 19, 2007 01:01 PM
