1990 Civic LX Chip?
Old Apr 3, 2013 | 09:08 AM
tanner_bentley's Avatar
Default 1990 Civic LX Chip?
Hi guys Im new to the site. I've been wondering though if there is a way to chip my 1990 Honda civic lx? It's got the 1.5 d15 engine with the dual point fuel injection. I've been looking at the bully dog chip but it says you need the obd2 port and I've looked up what my car has and it says it has the opd1 port. So if someone could help that'd be great!! Thanks.
Old Apr 3, 2013 | 10:08 AM
4drEF's Avatar
Keyboard Humorist
Default Re: 1990 Civic LX Chip?
You can probably chip it.
Chipping meaning that you remove or bypass the stock chip to a programmable one.
the problem is that there aren't any tunes for the 1.5 that you could load onto the new programmable chip.
Totally not worth doing anyway.
For under $100 you can do an MPFI swap. Much better for performance.
Old Apr 3, 2013 | 01:22 PM
JupiterEF's Avatar
I agree with 4drEF, doing the 4 injector swap is a big power gain, i did mine about a month ago.
things you will need:
OBD1 ECU (p06)
OBD0 to OBD1 ECU jumper harness
OBD1 Dizzy
OBD0 to OBD1 Dizzy jumper harness
Multi port intake manifold
OBD0 or OBD1 injectors
Resistor box if you are going to run OBD0 injectors
4wire O2 sensor although not necessary if you can live with the CEL.
there are so many write-ups on this along with making your own harness.
if you do this you will not be disappointed.
What's that?
Old Apr 3, 2013 | 01:25 PM
JuggerNaut-CTR's Avatar
Originally Posted by tanner_bentley
What's that?
Your car is dual point injection...swapping to mpfi (multipoint) will be better in terms of power increase over a chip.
Old Apr 3, 2013 | 04:30 PM
I'm really wanting to get better MPG
Old Apr 3, 2013 | 05:52 PM
When is the last time a tuneup was done?
If thats up to date, light wheels with smaller diameter tire.
I had hx wheels at one point (roughly 11 lbs a piece) with 195/55r15 tires. I saw around 3mpg highway increase and butt dyno said it was a lil quicker...
Old Apr 3, 2013 | 06:22 PM
F22Master's Avatar
FULL tuneup, small and light rims/tires, STOCK ECU.
Or, THIS:
http://ef-honda.com/main/viewtopic.p...e00686659cbc45
Old Apr 4, 2013 | 07:32 AM
4drEF's Avatar
Keyboard Humorist
Then stop spending money on 1990 technology and save your pennies for a Chevy Volt.
Old Apr 4, 2013 | 07:38 AM
nosc0pe420fgt's Avatar
I got my chip from eBay but don't no how to put it in.
Old Apr 4, 2013 | 08:10 AM
Cool...thanks for sharing
Old Apr 4, 2013 | 08:13 AM
I thoght so too!
Old Apr 9, 2013 | 10:29 AM
4drEF's Avatar
Keyboard Humorist
Got a link to that eBay listing?
I'm thinking it was for a 92+ LX. Those are chippable.
Old Apr 10, 2013 | 06:39 PM
Is there anyway I can put any type of monitor shower the mpgs that I'm getting?
Old Apr 13, 2013 | 07:00 AM
JupiterEF's Avatar
I don't think there is a way. the old BMW and Mercs that had these are just vacuum gauges they are not true to life.
The best way I found is to fill it til the pump clicks then reset the trip odo and run the car and when you get low fill it again and do the math.
dc5itracer
10
Mar 26, 2011 10:29 AM
Dkahn18
Feb 18, 2009 04:41 PM
lsvtec hf
Engine Management and Tuning
Jan 21, 2009 12:02 PM
nitewolf
Sep 3, 2007 07:03 AM
aVstAr
Dec 26, 2003 07:41 PM
