80mm DBW Honda Civic Si throttle body
Old Apr 3, 2013 | 06:31 AM
Spaceballsthelunchbox's Avatar
No Big Whoop
Default 80mm DBW Honda Civic Si throttle body
I think this falls under fabrication.
I got a call the other day from John at Hytech asking me if there was a Honda TB that could be bored to 80mm. I told him no, the most I had been able to bore a honda TB was 70mm by installing a sleeve. I know Honda now has a stock 70mm DBW TB but I have not seen it yet.
Anyways, since I had a 70mm TB started, I decided to see if I could push it even further and try to accomodate an 82mm bore. I have to have room for the sleeve wall thickness.
My concern was the flange since the sleeve was going to remove most of the space there and there would not be much room to put a gasket. So I installed a .125" thick 6061 aluminum flange that gave me room to get to 80mm and still have enough wall to fit a gasket.
To my amazement, there was room. Honda, very kindly, made nice and deeeep bearing wells on the Civic Si that allow the bearings to be pushed all the way out. The shaft is just long enough to reach the bearings on both sides. So I made one and it ended up being 80.125mm in diameter with a 84mm tapered inlet.
I have no idea how he is going to control such a large TB. A tiny opening of the butterfly lets a lot more air by than that same opening on the 60mm TB.
Here are some pics:
Old Apr 3, 2013 | 02:52 PM
Walterronny's Avatar
Default Re: 80mm DBW Honda Civic Si throttle body
good job!! price including TB?
Old Apr 3, 2013 | 03:44 PM
egb18c5's Avatar
who makes the sleeve? darton? lol jk, thats a very nice piece, i'm glad your still trying new things with the OEM TB's
Old Apr 3, 2013 | 04:22 PM
No Big Whoop
I don't want to post that here, it might get me in trouble.
Let me just say, less than any other aftermarket DBW TB.
Old Apr 3, 2013 | 07:29 PM
efHondefender's Avatar
you're a regular, god damn hero
Old Apr 3, 2013 | 08:25 PM
SovXietday's Avatar
That, quite honestly, is a completely ingenious way of going about things. Great job.
Old Apr 12, 2013 | 10:13 AM
AWOC's Avatar
Great job! I like the way you went about it!
Old Apr 12, 2013 | 05:09 PM
smilindave's Avatar
you sir, are a god! to have the patience to do this is unreal!
dave
Old Apr 17, 2013 | 08:52 PM
crazyjetsfan22's Avatar
Looks great!
Old Feb 16, 2014 | 04:59 PM
fg2civicsi's Avatar
Where can i get one of these?
Old Feb 16, 2014 | 06:26 PM
1998GsRIntegra's Avatar
http://www.maxbore.com/index.html
sol_searchin
Honda CR-V & Element
Nov 5, 2014 04:56 AM
RedlineMotive
Performance
Nov 13, 2010 05:34 PM
jameskersten1
Honda Civic (2006 - 2015)
Aug 29, 2006 12:40 AM
Audi RS4
Sep 17, 2004 09:52 AM
lilbill3554
Jan 28, 2004 07:39 PM
