Transmission & Drivetrain Gearboxes, Differentials, Clutches
B Series Mugen LSD Question (2 way clutch type)
Old Apr 3, 2013 | 04:57 AM
beenba's Avatar
Default B Series Mugen LSD Question
Does anyone know the thickness specification for the clutch plates in a Mugen LSD? I would like to measure mine.
Its a few years old and I'm debating shimming it (or buying new clutch packs), but I do not know the original thickness of the plates to see how much mine has worn..Thanks.
Edit: Seems it may only be a 1.5way..not sure how to tell the difference between 1.5 and 2way.
Old Apr 3, 2013 | 06:02 AM
Aquafina's Avatar
Default Re: B Series Mugen LSD Question (2 way clutch type)
Contact King Motorsports 262-522-7558.
Old Apr 3, 2013 | 12:56 PM
beenba's Avatar
Just called, they do not have the spec and I was asked to email scott - however I have been doing that for the past 3 months and he has not gotten back to me.
I'm going to mic the friction plates tonight and I will see if they are all consistent to one another just to give me some sort of baseline I guess.
Old Apr 4, 2013 | 11:40 AM
Aquafina's Avatar
That's odd since they're Mugens NA Distributor. Sorry I couldn't help more.
Old Apr 4, 2013 | 03:33 PM
beenba's Avatar
No problem.
Just to update this thread for future if anyone needs. I did find this website, and it lists some specs. (http://www.nengun.com/mugen/lsd).
Mechanical Type
45 degree cam angle
9kg/m Initial
Option LSD Rebuild
6 x Friction Disc - t = 1.75mm (0.0689in)
2 x Friction Plate - t = 1.65mm (0.0645in)
2 x Frication Plate - t = 1.55mm (0.0610in)
4 x Spring Plate - t = 1.65mm (0.0645in)
When I mic'ed my plates I got an average of 0.0693" for the plates with ears, and 0.0650 for the plates w/o ears. All measurements were within 0.0003" which could be error in my mic. These seem to match up whats listed above too. My unit definitely showed little to no wear on all the plates.
I should also mention the entire unit had 0.090" preload when screwing down the 4x phillips screws.
Builda'Teg_92
Nov 29, 2012 08:13 PM
jfeniello
Aug 27, 2012 05:00 AM
EJ1B18c
Jun 4, 2011 08:27 AM
88 EF Hatch
Feb 22, 2011 01:22 PM
SI_frankenstein
Mar 6, 2008 12:26 AM
