rear sway bar
Old Apr 2, 2013 | 02:00 PM
ryanmh22's Avatar
Default rear sway bar
does anyone know if the rear sway bar off a 88 crx si would fit an 89 crx si? i know the lca are different but not sure if that effects how the sway bar would mount, so does anyone know?
Old Apr 2, 2013 | 02:15 PM
90_EX_Civic's Avatar
Default Re: rear sway bar
think you might be okay.
Old Apr 2, 2013 | 02:31 PM
ryanmh22's Avatar
exactly what i wanted to hear, thanks!
M-benz's Avatar
Is it better if we just upgrade to the thicker one ? What are the options here ?
Old Apr 2, 2013 | 02:35 PM
wow, thread jack.
google would help with what choice you would want if you want to go bigger. but the two that stand out the most is ST, and ASR.
Old Apr 2, 2013 | 02:36 PM
Tyson's Avatar
mounts exactly the same. no difference. both LCA have the same mounting hole positions.
Old Apr 2, 2013 | 02:54 PM
ryanmh22's Avatar
good to hear
Old Apr 8, 2013 | 02:35 PM
ryanmh22's Avatar
so neglicted to mention the fact that my 89 is an si clone... so where the sway bar would bolt into the body there are just holes with no nuts. any of you know of a solution? i thought of just welding the brackets into place but am wondering if there is a less permanent solution?
Old Apr 8, 2013 | 02:37 PM
Tyson's Avatar
theres a thread in the faq with several alternatives if you read carefully.
Old Apr 8, 2013 | 02:52 PM
4drEF's Avatar
Keyboard Humorist
Brackets with a nut or threaded hole on the backside might work.
That is a lot of pulling stress on a weld so I'm not sure how long it would last.
It might be fine.
Maybe cut a slot in the side of the rail and put a plate with a nut welded on inside.
Then weld the hole in the rail back up.
Typical solution is to use a hole drill and cut in through the trunk floor.
Old Apr 8, 2013 | 03:03 PM
ryanmh22's Avatar
as far as welding I am a welder by trade so a good weld should be stronger than the metal around it, hmmm i will have to give it some thought and see what i can come up with
Vagitarian
15
Oct 7, 2013 11:08 AM
DoubleDirtyC
Aug 17, 2010 09:18 PM
ThefirstPACT
22
Feb 8, 2005 11:42 AM
juicy.koreans.suck
Jun 5, 2002 06:58 AM
