Transmission & Drivetrain Gearboxes, Differentials, Clutches
S20-B000, just swapped noises/issue
Old Apr 1, 2013 | 06:26 PM
OGxruiner's Avatar
Default S20-B000, just swapped noises/issue
here's a bit of backstory:
'93 EH2
JDM D15B Vtec
S20-A000 (old trans, worked fine.. but horrible ratio)
S20-B000 ("new" trans, swapped this Saturday)
BRAND NEW axles
Clutch kit >5,000 (was fine before swap)
I traded some misc parts for this EX trans, because I was running a CX trans and the gear ratio was terrible. I swapped everything in and took it for a test drive. Every gear was smooth as butter BUT I did notice a strange noise on the passenger side.
The sound, to me, sounds similar to a supercharger whine and only occurs from 2nd-5th gear. It gets louder as I accel. So, I added a little more MTF and the sound is still as loud as before. As I was coming home from work I stopped at a stop sign and noticed a lot of smoke pouring into the cabin. I wasn't sure if it was possibly from an issue within the trans or if maybe I had spilled some fluid...
I am more concerned with the noise itself than the smoke, because I feel 90% sure I spilled a little fluid. Any ideas? I've seen SOOO much stuff--
"It's your throw-out"
"It's your syncros"
"It's this..."
"It's that..."
I am really only looking for responses from trans gurus! If you don't work on transmissions for a living, or build race cars, please keep your guesses to yourself. Thanks in advance!
Old Apr 1, 2013 | 07:32 PM
Aquafina's Avatar
Default Re: S20-B000, just swapped noises/issue
How does the fluid look, any flakes? How loud is the noise at cruising speeds when light on the throttle?
A whine that isn't caused by the pitch of the gear teeth is usually caused by a damaged gear or gear/shaft misalignment.
Old Apr 2, 2013 | 05:10 AM
OGxruiner's Avatar
Fluid is brand new. i don't have a garage or tools so i have to drive on it for another day (12 miles both ways) to get to work.. so I cannot check for flakes.
the noise has since quieted in 3-5. but is still noticeable in 2nd. i am thinking i am just gonna have to source a new trans and do the swap again at this point..
SoHc94
Aug 15, 2011 09:52 PM
kleenest
Jul 27, 2011 11:07 AM
