91 accord "s" lit on & check engine lit
Old Apr 1, 2013 | 04:02 PM
az90EF's Avatar
Icon6 91 accord "s" lit on & check engine lit
whats up i have a 91 accord "s" lit on & check engine lit on i jump it. I got 6 short blinks on the check engine lit. And for the "s" lit just one long one. car runs fine but when i have the A/C on and come to a stop it idles down almost turning off but stay running. let know what you guys think. thanks
Old Apr 1, 2013 | 04:29 PM
Mishako129's Avatar
Default Re: 91 accord "s" lit on & check engine lit
Google is your friend.
CEL LIGHT:
6 ECT - water temperature sensor
S LIGHT
10-Coolant Temperature Sensor open or shorted.
You have a problem with your coolant sensor. Check it out, its located on the water pipe (closest to the right in this pic),
Old Apr 1, 2013 | 04:31 PM
Mishako129's Avatar
https://honda-tech.com/forums/honda-accord-1990-2002-2/coolant-temperature-sensor-question-3008918/
Old Apr 1, 2013 | 04:54 PM
az90EF's Avatar
cool thanks i'm going to check it ill let you know what i find
Old Apr 2, 2013 | 04:32 PM
Lost Again's Avatar
Closest to the right, NO. The ECT is the two wire oil coated connector under the dist cap in the pic....yellow"ish" connector. Almost dead center of the pic.
Closest to the right is "thermo b"...it controls the cooling fan operation when the car is shut off.....green connector.
Old Apr 3, 2013 | 06:13 AM
az90EF's Avatar
Yea I tired the green one still cel lit ill try the yellow one now ill update what I find. Thanks
Old Apr 4, 2013 | 05:28 PM
az90EF's Avatar
yea you were right it was the ect under the dis cap it fixes my problem no cel lit or "s" lit hope this anyone else thanks alot
Old Apr 7, 2013 | 04:17 AM
Lost Again's Avatar
Glad you got it
sammi's accord
Dec 31, 2013 09:54 AM
ANDREWASOAR
Oct 14, 2013 03:15 AM
bebrahimji
Mar 23, 2004 06:32 AM
Monty
Sep 28, 2002 08:56 AM
