questions about ac bracket mount
Old Apr 1, 2013 | 02:25 PM
joes-92's Avatar
Default questions about ac bracket mount
just now getting around to installing the ac bracket mount(has been missing since i bought it). anything special about the nut after the motor mount? will any run of the mill hardware store nut work? is there anything else needed besides new mount and bolts?
thanks in advance.
Old Apr 1, 2013 | 04:32 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: questions about ac bracket mount
Are you referring to the nut for the frame mount? Remember all the bolts and nuts on Hondas are metric thread. Search on Majestic Honda's catalog for the correct bolt/nut.
Old Apr 1, 2013 | 04:47 PM
apexi_rsx's Avatar
are you talking about the 17mm or 19mm nut that holds the mount in? if so just go to your local junkyard and grab one. it also has a washer on it as well.
Old Apr 1, 2013 | 05:11 PM
Wdpfreak145's Avatar
Those torque mounts don't serve any real purpose and are unnecessary in my opinion. 4 thing strips of rubber aren't going to offer much stability for the engine.
Old Apr 1, 2013 | 05:12 PM
grumblemarc's Avatar
The Grumpiest
Speak for yourself. My Hardrace mounts make everything rock solid.
Old Apr 1, 2013 | 05:24 PM
joes-92's Avatar
oak ridge huh? im from manchester, the home of bonnaroo!
anyways, dont serve a purpose? im out of ideas and my car bucks violently at light throttle at any speed(big toe on the gas pedal). i figured it was the mount.
ill check majestic as well.
xxSOLxx
Honda CR-V & Element
Jun 13, 2014 07:54 AM
StreetEG
11
May 20, 2005 06:08 AM
rasinhell
Mar 18, 2005 08:45 AM
Dr. Gonzo
Sep 6, 2003 11:10 AM
ZUL8R
May 20, 2003 06:24 PM
