Falken azeinas vs s-03 pole postions
in a 205/50/15 witch tire is the best best one. price and noise factor does not matter. i drive my car like it should be driven and i love to take corners fast. i was going to go with the s-o3's but then i started to read about the aezinas and they look like a great tire to. what shold i get?
[Modified by Vampyre, 10:05 PM 10/22/2002]
Never had any experience with the Azenis but I hear they are good tires for that price. I have the So-3's and they are ****** awesome tires. Best tires I have ever bought.
Azenis aren't nearly as good in the rain as S-03's. I just took my 195/50 s-03's to gingerman. It was cold, so they didn't overheat, but they blistered over pretty good, but I did not lose traction all day. They held very nicely considering what they are. All in all, I was overly impressed. Now, that does not mean they are a good idea for track use. But, it is all I had and luckily the temp was low. I have a feeling at high track temps these tires would practically melt.
Around town, i love the s-03's. If they are for street use, why not save big money and get the 195/50s? If you need 205/50 for whatever reason, it is hard to pass on the affordable Azenis... but in my opinion the s-03's are a better all around street tire (i.e., hot/cold, rain, etc).
195/50/15 they make it in that size? i thought the smallest size they came in was the 205 50 15. ok so witch would be a better size to go with 195 50 15 or the 205 50 15. will the 195 50 cause the mph to be off like the 205 does?
Even if the Azenis were the same price as the stock 010's I'd take the Azenis, I love them, to date they are the best tires that have been on my car (and also the cheapest!). However I have not yet tried the S03's.
195/50-15 S-03
$79 a tire....
the speedo reads 3% fast with 195/50-15's. I don't know about 205/50-15's, but my guess is that it is around 2% too slow on the speedo. Just checked the tire size calc. 205's will be 1.6% too fast on the speedo. In my opinion, both of those are insignificant.
$79 a tire....
ok i think i am going to get the s-03 in the 205/50/15.
FYI - From what I've heard, 205's will give you slower turn-in response due the width of the ITR rims.(assuming you have stock rims).
I don't see how you can justify spending extra money for a tire that is only 10mm wider and has a marginally taller sidewall. Oh well, your decision.
To me, better turn in and saving 31 dollars a tire is all I need to decide between 195 and 205.
[Modified by 1107, 5:14 PM 10/22/2002]
What size rims do you have? Stock 15x6" or aftermarket 15x7"?
You've never heard of turn in?
I'd like to save 124 on a set of tires, if it was a question of 195/50 or 205/50. We've given you all the info you need about these two tires. Go buy them!!!
