Transmission & Drivetrain Gearboxes, Differentials, Clutches
howi know if my tranny is GSR or LS
Old Apr 1, 2013 | 08:22 AM
h22killer's Avatar
Default howi know if my tranny is GSR or LS
i dont have stickers on it, no VIN # , the tranny have a hidden code or something. i jsut wanna know if my tranny is gsr or ls , my tranny is hydro
Old Apr 1, 2013 | 08:27 AM
GagnarTheUnruly's Avatar
Default Re: howi know if my tranny is GSR or LS
There is often a stamp on the transmission case, visible if you look straight at it from the engine bay.
Otherwise the only way to know without taking it apart is to see what rpm you are at on the highway. If 70 mph has you at 3000 rpm it's an LS transmission. If you are at 3500 rpm it's a GSR transmission. Of course this goes out the window if the transmission has custom gearing.
Old Apr 1, 2013 | 08:29 AM
h22killer's Avatar
i didnt put in my car , bcs im making a h2b conv, i just bought to some guy, but the tranny didnt comes with stickers or vin # , and he said its a gsr but i dont trust him, and that my question i just wanna know if the case have a hidden code on it
Old Apr 1, 2013 | 08:36 AM
xTyFighterx's Avatar
http://www.superhonda.com/forum/f5/b...-codes-218900/
here are the codes
Old Apr 1, 2013 | 08:39 AM
h22killer's Avatar
^ i know ratios and codes bro, but my tranny didn't comes with codes or stickers nowere !!!!
Old Apr 1, 2013 | 08:43 AM
your orignal post asked for codes? resort to the rpms then like stated above thats the next easiest way
Old Apr 1, 2013 | 08:45 AM
h22killer's Avatar
i buy the tranny now, and yes im asking codes but i need if the tranny comes with other codes hidden because my tranny the guy remove the vin # and sticker front of the tranny, he paint the case maybe for that he remove the stickers and vin #
Old Apr 1, 2013 | 08:46 AM
just check the rpms like stated above
Old Apr 1, 2013 | 08:48 AM
h22killer's Avatar
cant bcs i buy this tranny for a h2b conv and i didnt start on my projetc so that my question, the tranny case have a hidden code ?
Old Apr 1, 2013 | 08:55 AM
JuggerNaut-CTR's Avatar
94-01 gsr = s80 or y80
94-01 ls = s80
92-00 sir2 = s80 or y80
95-97 jdm itr & 97-01 usdm itr = y21 , y80, s80 or s4c
With those codes stated would be hard to tell without the vin.
If there is no vin tag the only way to tell before buying is to open it up and count the teeth...
Only way to tell without opening and just biting the bullet and hoping the seller is legitimate, would be install and note mph vs rpm
There is no "hidden" code....
ls: 64/15
gsr:66/15
Old Apr 1, 2013 | 08:57 AM
h22killer's Avatar
damm, ty alot
Old Apr 1, 2013 | 09:22 AM
If you have the transmission in front of you, you can also spin the input shaft by hand and count the revolutions of the driveshaft.
Old Apr 1, 2013 | 10:17 PM
h22killer's Avatar
How i do that bro? Explaind me plz how i can count the revs
Old Apr 2, 2013 | 05:41 AM
Slide a axle in one side and mark 12 o'clock on the axle. Slide a clutch disc on the input shaft and mark 12 o'clock.
Rotate the input shaft 4.4 times, if the mark on the axle is at 12 o'clock again after you rotated the input shaft, its got a 4.4 fd.
If it falls short of 12 o'clock, it has a 4.266 fd.
4.4 fd = gsr
4.266 = ls
pliskin679
Aug 11, 2010 10:46 PM
94whitegsi
Dec 13, 2006 09:05 PM
BoOsTiN Dc2
May 30, 2005 03:30 AM
integraautox
Aug 7, 2003 09:32 PM
non-VTEC
Jun 28, 2001 03:25 AM
