Two Original USDM OBD1 P72 ecus...Also JDM OBD2B ecu
I had these two ecus saved up in case I ever needed them, but I never did, and I am selling anything I have that has value so that I can continue saving for a downpayment on a house. Both have been tested in an OBD1 integra GSR and both worked fine. Absolutely no issues, and neither one has ever been messed with. Very rare find these days. I am looking for $125 each. Offers will be heard but I would rather not mess with trades.
The other P72 is an OBD2a JDM 5 speed ecu. It also works just fine in OBD2A cars, but as you may know, jdm ecus do not communicate with OBD2 scanner tools, and therefor you have to check it using the old OBD1 trick (jump the small blue plug near the ecu). If your states require that your car can be scanned this is not the ecu for you. If not, it would be a great ecu for a gsr swapped 96 to 98 civic, or 96 to 99 integra. Looking for $100 out of this ecu. I will have pictures up tonight. Thanks!
SR200
Aug 13, 2011 06:49 PM
weaksoN!
Nov 14, 2010 02:25 AM
u2civic1
Apr 1, 2003 02:44 PM
