lowering springs
Old Mar 31, 2013 | 06:01 PM
89c1vicSi's Avatar
Default lowering springs
ok well ordered some skunk2 lowering springs the other day, an now getting bashed on cuz someone is sayin they are ****. any opinions?
Old Mar 31, 2013 | 06:20 PM
xTyFighterx's Avatar
Default Re: lowering springs
Who cares what other people think
Old Mar 31, 2013 | 06:36 PM
89c1vicSi's Avatar
well supposibly they are crap cuz they bounce to much and give ugly stance. I cant find any pics of a ef with skunk2 springs on them, just coilovers.
Old Mar 31, 2013 | 07:04 PM
Spug's Avatar
If the dampers/shocks/struts are good, the springs can't bounce.........
Old Mar 31, 2013 | 07:06 PM
89c1vicSi's Avatar
see that's what I was thinkin but they keep sayin look at spring rates, I have no clue wtf they talkin bout lol
Old Mar 31, 2013 | 07:58 PM
How much of a drop are they?
Old Mar 31, 2013 | 08:07 PM
89c1vicSi's Avatar
Front Spring Rate (Tender / Main): 257 lb-in / 559 lb-in
Rear Spring Rate (Tender / Main): 112 lb-in / 485 lb-in
Drop (Front / Rear): 2.25” / 2.00”
Note: 1 lb-in = 0.0179 kg/mm
straight from skunk2 webpage
Old Mar 31, 2013 | 08:10 PM
Ur gonna be On stock struts or what?
Old Mar 31, 2013 | 08:13 PM
89c1vicSi's Avatar
was gonna use new oems, an lookin for extended top hats
Old Mar 31, 2013 | 08:16 PM
That alot for the stock shocks to handle might be a bit bouncy but no dout ur going to blow some shocks. And with springs ur gonna be like 2.5 up front 2.25 in the rear after they settle
Old Mar 31, 2013 | 08:20 PM
89c1vicSi's Avatar
even with the extended top hats? what decent priced shocks would u suggest than?
Old Mar 31, 2013 | 08:30 PM
24TEN's Avatar
PHANTOM MENACE
xTyFighterx is pretty much right on the money as far as the settled height. If you want an upgraded shock look at koni yellows or similar.
Old Mar 31, 2013 | 08:33 PM
Jason Sensation's Avatar
The question is... What do you want the suspension to do?
A) if for track use, get Koni shocks. As they're damper adjustable so you can play with how soft or hard you want it, the valving is more suited to aftermarket springs and will last a big longer.
B) "stance" then sell the springs and buy coil overs. As they're a lot better for dropping cars to the ground but it won't handle great at full adjustment.
C) a better ride for going to work, a little bit lower etc. then use these springs go buy some NEW OEM shocks either from Honda or your local KYB stockist Nd have them shortened to match the springs. Again wont handle fantastic but will be suffice for every day use.
Make sure what ever you do, compliment the suspension in other areas. Upgrade your sway bars, strut braces, replace worn out bushes and give your steering system an overhaul.
I'm not an expert but after playing with Konis in my rx7 race car they're great for both road and race but you pay the price. Keep an eye out on eBay as I picked up a set of Koni Yellows and springs with sleeves for $340nzd($270usd) on trademe(our version of eBay)
Old Mar 31, 2013 | 08:45 PM
89c1vicSi's Avatar
well I mostly drive back an forth to work, go out once in awhile an I mean once a month to the meets an maybe race a buddy or too. no track tho of course. has anyone heard of these?
http://www.ebay.com/itm/STAGG-SHS-SET-OF-4-SHOCKS-HONDA-CRX-CIVIC-89-to-91-/400327495890?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A1989%7CModel%3ACivic&hash=item5d3560d0d2&vxp=mtr
Old Mar 31, 2013 | 08:54 PM
89c1vicSi's Avatar
has new steering rack and tierods, gonna look into a new sway bar, idk bout strut braces tho?
Old Apr 1, 2013 | 02:51 AM
Strut braces aren't a must have. Just nice to have, takes out the minimal flex in your top part off the frame.
Old Apr 1, 2013 | 04:28 AM
89c1vicSi's Avatar
oh wait ur talkin bout strut bars lol never heard the term strut brace haha but ya I want upper and lower for rear and front, gonna order that from dna motoring
Old Apr 1, 2013 | 08:13 AM
Stagg SHS Set of 4 Shocks Honda CRX Civic 89 to 91 | eBay
never heard of them but im not going to down somthing i have no experince with its your money you can buy what you want and try what you want but from my experience with that drop your shocks are going to go to crap. Koni Yellows are a great shock with a great warrenty and can handle the drop. there are other options to you just have to search. No one on here is going to tell you to go with off brand ebay stuff most likley those shocks are like a stock replacement which wont help your case you might be ok with those shocks and those springs for a little while who knows, but i would certainly save up to buy some nice shocks with a great warranty and great customer service it will save you in the long run. suspension is a major componet in your car not only should you buy shocks that have quality but also for your saftey most importantly just do a little research. good luck man hope everything works out!
Old Apr 1, 2013 | 12:23 PM
89c1vicSi's Avatar
thanks, and those I can get with springs for extra that lower the car I think 2in it said, but don't need springs just shocks.
Old Apr 1, 2013 | 12:44 PM
grumblemarc's Avatar
The Grumpiest
OMG don't get those Staggs. They are a quick cheap setup for OEM. People get those when they are nearly broke and cannot afford better or are about to flip a car on the cheap.
Any OEM replacement shocks and those Skunks are a straight up mismatch. The shocks will be 'underdamped".
And extended top hats don't help you get any lower. I don't know WHERE you people are getting this **** from. All they do is increase shock travel for car that are very low.
Get the Yellows.
Old Apr 1, 2013 | 12:52 PM
89c1vicSi's Avatar
I never said the top hats help get lower its just to help from bottoming out.
Old Apr 1, 2013 | 01:01 PM
89c1vicSi's Avatar
half tempted to say screw it an go back to coilovers. cant afford a set of 500$ yellows right now, to many bills at moment.
Old Apr 1, 2013 | 01:20 PM
24TEN's Avatar
PHANTOM MENACE
Back to which coilovers specifically? Might not be any better over the springs if they are those generic slip on coilovers.
Old Apr 1, 2013 | 01:23 PM
89c1vicSi's Avatar
yes slip ons but haven't had any issues with shocks, I have the originals on it now with them on an no problems.
Old Apr 1, 2013 | 01:32 PM
89c1vicSi's Avatar
ok well someone on another site suggested kyb's, so how bout these even tho my model didn't show up
http://www.ebay.com/itm/KYB-GR2-SHOCKS-89-91-HONDA-CIVIC-CRX-FULL-SET-OF-4-/150779687460?pt=Motors_Car_Truck_Parts_Accessories&hash=item231b2b7224&vxp=mtr
