Can I block off these hoses??
Old Mar 31, 2013 | 10:48 AM
mungface78's Avatar
Default Can I block off these hoses??
I'm about to throw my b20 in my ef and need help... There are some hoses that I want to block off, If I can block these off without welding, what have you guys used to block off? Also there are 2 lines on my trans(ys1) that I have no clue where to hook them up to.. Does anybody know where they go? Thanks in advance y'all.
Do I have to wire in the oil pressure switch if I have an aftermarket gauge?
Old Apr 1, 2013 | 03:54 AM
mungface78's Avatar
Default Re: Can I block off these hoses??
I have one more...
Old Apr 1, 2013 | 07:37 AM
hondamark35's Avatar
looping them is the most common practice i believe. it's the easy and reversible alternative to welding or brazing everything shut. the two on your transmission (speed sensor really) are part of the power steering system. if you aren't running P/S then you can just remove them, no need to plug anything there.
Old Apr 1, 2013 | 10:16 AM
mungface78's Avatar
Thanks man I will do that. Have any idea where the hose hanging off the throttle body goes? Its an ls intake Mani if that helps.
Old Apr 2, 2013 | 12:16 AM
teggy899's Avatar
I by passed my oil sender when I hooked up my gauge
Old Apr 2, 2013 | 03:52 AM
mungface78's Avatar
I figured I could do that. I still stumped with what to do with those lines coming from the throttle body...?
Old Apr 2, 2013 | 09:20 AM
you don't need to do anything with them. one is "in" and the other is "out." if you don't run a line to them (bypass with a loop on the metal pipe) then you can just ignore that area coolant wise.
Old Apr 2, 2013 | 10:23 AM
mungface78's Avatar
Thanks alot you guys! Now I can proceed with my swap!
ASR_RAMBO
Jul 29, 2005 04:04 PM
sPaRk'iT
Jan 30, 2004 10:45 AM
iamthemouse
Aug 18, 2003 06:27 PM
integra6650
May 27, 2003 02:11 AM
