O2 Sensor Problem, please help!
Old Mar 31, 2013 | 12:54 AM
rsangha13's Avatar
Default O2 Sensor Problem, please help!
Hey guys,
So I got a b18c5 in an em1 with a few bolt-ons (I-H-E) and its throwing me a code for upstream o2 sensor. Well i got the o2 sensor and went to replace it only to see that the previous owner put the downstream o2 in the upstream the problem however is that i cannot find the upstream o2 plug anywhere so i think he may have cut it from the harness because i see lots of splicing. My question is that is it possible to run an upstream o2 to a secondary o2 plug? Or can you just put a downstream o2 in the upstream spot?
Thank you
Old Mar 31, 2013 | 06:09 AM
raverx3m's Avatar
Default Re: O2 Sensor Problem, please help!
its not a part of engine harness usually.
its in the chasis right abovethe exhaust there should be a hole.
Old Mar 31, 2013 | 07:18 AM
98vtec's Avatar
moderator emeritus
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/all-motor-na-section-content-%2A%2Aplease-read%2A%2A-3134843/
jdm1980
Mar 10, 2008 08:13 AM
SpoonEk253
Mar 22, 2006 06:10 PM
gsrhatchy
Northern California (Sales)
Jul 30, 2005 02:32 PM
allmotorsi04
Nov 24, 2003 07:51 PM
AfEn808
Jan 21, 2002 05:51 PM
