Headlights ajustment
Hi! I have 2013 civic lx and for the past 3 days the headlights are very dim to the point were you can barely tell they're on. Can anyone tell me how to make them brighter? The manual does not help. *does not have auto lights option. Thank you in advance :-)
Check to see if the fuse is corroded or damaged. If the fuse is ok, check the battery connections are tight. If they are good, check the ground wire connection to the car chassis where the headlight wire harnesses go to each light. You might want to have your manual with you for harness tracing so you know which wires to look at and for the fuse number.
be4unvme
22
Jul 2, 2012 10:52 AM
