Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2003 honda civic dx 1.7ltr engine rough idle
Old Mar 30, 2013 | 03:56 PM
carlkim's Avatar
Default 2003 honda civic dx 1.7ltr engine rough idle
i have a 2003 honda civic and as we were on our way home from purchasing a 2009 honda crv we encoutered a problem with the civic. The engine lost its power and the engine light which has been on for awhile started flashing .Its a 1.7 ltr engine that has worked fine since we've had the car(approx. 4yrs.). We just had a recent tune-up last july/12. Anyways while the engine is running (almost...appears to idle ruff) if i pull the wire off of the coil(#3) there is no change in the engine. The other wires when pulled off will make the car quit. As i mentioned before the engine light was on solid and the mechanic said it was a censor by the fuel tank and not to worry about it, its common for them to go. I have changed the coil and the spark plug which was covered in a hard black something(carbon deposits...maybe) just tonight and the engine light still flashes and the engine might have a little more power but it still chugs. Also it smells like a snowmobile...like gas fumes while its idling. any help would be greatly appreciated. thanks
Old Mar 30, 2013 | 04:17 PM
toyomatt84's Avatar
Sanji
Default Re: 2003 honda civic dx 1.7ltr engine rough idle
Have you done a compression check on cylinder #3?
Old Mar 30, 2013 | 04:20 PM
dempsi's Avatar
How many miles are on the car and what was done on the tune-up last performed?
Seems that the car has lost spark on at least one cylinder and by removing the other wire, the car doesn't have enough spark to continue running.
Old Mar 30, 2013 | 05:16 PM
carlkim's Avatar
i have not done a compression test, and there is 177,000kms on the car, a new timing belt, spark plugs, coils, and filters where changed. We only took one wire off at a time when we tried removing the wires off of the coils, but the car almost died when we did remove them. #3 didn't do anything to the motor as its running ruff anyways.
Old Apr 19, 2013 | 02:54 PM
carlkim's Avatar
no fire at all going to #3 coil
Marshal kokogyi
Apr 4, 2017 07:31 PM
dh1212
Apr 2, 2016 04:08 AM
Rayco Brizu
Jan 10, 2014 06:10 AM
washani
Nov 3, 2005 12:56 PM
