Honda CR-V & Element 2WD & 4WD Element & CR-V
M/T CRV CLUTCH MOD FOR SOFTER PEDAL FEEL
Old Mar 29, 2013 | 04:34 PM
TSIKOY's Avatar
Default M/T CRV CLUTCH MOD FOR SOFTER PEDAL FEEL
PARTS NEEDED:
CIVIC 92-00/CRV 98-01 CLUTCH SLAVE (3/4") BOLT ON PART
ANY TOYOTA 7/8" CLUTCH SLAVE REPAIR KIT
Now we need to make the bore of the clutch slave bigger from 3/4"(stock) to 7/8"
Here is a comparison of the piston of the clutch slave
7/8" on the left and 3/4" on the right
Brought my SLAVE at a LOCAL MACHINE SHOP to make the SLAVE's BORE bigger,they did a great JOB but didn't do a MIRROR FINISH for the inside..So DIY MIRROR FINISH
DRILL PRESS with GI TUBE attachment to do the MIRROR FINISH
I bought 600 grit sandpaper and attach it on a gi tube. I used my drill press for it.
After sanding it off. I finish it with honing paste.Ones used for valves.
Here is the finished clutch slave
Below are the finished measurement
PISTON:
CLUTCH SLAVE:
The BASIC PRINCIPLE of the MOD is found on HYDRAULIC SET-UPs
Old Apr 1, 2013 | 09:14 AM
jdm_bones's Avatar
Default Re: M/T CRV CLUTCH MOD FOR SOFTER PEDAL FEEL
You should make a few of them, and sell them.
Old Apr 1, 2013 | 11:20 AM
94EG8's Avatar
Seagull Management
So how well did this work out? Was there a big difference in the pedal effort? I could see this being a much bigger benefit to the civic/integra guys with with stiff puck clutches.
Old Apr 8, 2013 | 09:25 AM
TSIKOY's Avatar
I did make a few and sold to our local club
It is not pain in the a%# when in traffic, huge difference from the stock
Old Apr 18, 2013 | 10:37 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
While this is all great, the problem would be a greater distance needing to be traveled with the clutch pedal. It may be fine for a vehicle that is babied, but for people racking out the gears it could cause issues. I haven't done the math or calculations but it is something that should be considered.
Old May 29, 2013 | 01:46 AM
mikkov's Avatar
just the solution i was looking for, do you think the slave could be bored out any more or is that the limit? i'd like to try 1".
Old May 29, 2013 | 04:50 AM
JZiggy's Avatar
What diameter is the master cylinder? You could calculate the actual hydraulic advantage (or "leverage")
Since the force of the slave cylinder is based on area, going from 3/4" to 7/8" should give you a 36% advantage. Cool.
Dre_559
May 28, 2009 08:23 PM
Kyle244R948
Nov 26, 2008 01:25 AM
CodyC142
15
Nov 20, 2006 09:55 PM
tvman
Jul 16, 2005 11:30 AM
integra pride
Oct 12, 2004 03:58 AM
