Honda CR-V & Element 2WD & 4WD Element & CR-V
Crv 4wd Header. To Stay Away From.
Old Mar 29, 2013 | 12:18 PM
Dc2_ShowStopper's Avatar
Default Crv 4wd Header. To Stay Away From.
Hello Fellow Techs,
Im doing more this so everyone is aware, i recently been looking for 4wd exhasut flex pipe. As you know no normal header will not work without fabrication. I recently purchase this header http://www.autopartswarehouse.com/sk...gs+Best+Seller
Bosal-Part # W0133-1798175. Just to let everyone this will not work the weld are completly off and does not clear the oil pan. I called the company and i will be refunded they will look into removing the part due to fitment issuses complainants but none are listed anywhere. Unfortunately i just settle on forking up the extra cash and going with an "OEM'. Should be in by next weekend.Hope this helps.
Old Mar 29, 2013 | 02:09 PM
LDForget's Avatar
Default Re: Crv 4wd Header. To Stay Away From.
Thanks for the tip. I'm sure people will appreciate it.
Old Mar 30, 2013 | 07:22 AM
Originally Posted by GRAFH
It doesn't say anywhere in the link it's for awd model. So how is it their fault?
I called prior to ordering and when you call the company this is the one they direct you to. i was skeptical at 1st about ordering it and i was right.
slow91crx
29
Jun 12, 2006 01:53 PM
junbb1
Mar 24, 2004 05:43 AM
7rrivera7
Jan 17, 2003 09:55 AM
IWearMyKswiss
Jan 15, 2003 09:29 PM
eg6madness
Aug 7, 2002 08:24 PM
