leak from feed line connecting to injectors
Old Mar 29, 2013 | 08:23 AM
rdtigue's Avatar
Icon6 leak from feed line connecting to injectors
What do I need to do to fix the leak from the fuel line connecting to the injectors? Its coming out from the brass connector. You can smell gas and see it leaking. Bubbles after driving the car. Would attach picture but cant figure out how to upload the pic.
Thanks
Old Mar 29, 2013 | 08:26 AM
grumblemarc's Avatar
The Grumpiest
Default Re: leak from feed line connecting to injectors
Hrm? Brass connector? What car is this? Do you have crush washers installed (if this is where I think it is)?
Old Mar 29, 2013 | 08:36 AM
jbpnoman's Avatar
Under the hood, you should have fuel filter -> fuel line -> fuel rail -> injectors. At which of those connections are you leaking? Specificity is important here. Some of those fittings use double crush gaskets, some use rubber o rings, and some use a mated fitting.
Old Mar 31, 2013 | 09:10 AM
rdtigue's Avatar
Is it possible to upload a picture so I can show where the leaks is coming from. Its leaking from the brass connector.
Old Mar 31, 2013 | 09:13 AM
rdtigue's Avatar
94 Honda Civic EX
Old Mar 31, 2013 | 09:22 AM
The Grumpiest
https://honda-tech.com/forums/showpo...37&postcount=2
Old Mar 31, 2013 | 10:25 AM
B_Swapped93's Avatar
Brass fitting most likly you're talking about the banjo bolt(s). Either the one that connects to the fuel rail but more likly it's the one that sits on top of the fuel filter. could just be you'r missing you'r washers there should be 2. but it could be the line inbetween which is not a hard fix either.
Alcatrax30
Jun 18, 2015 01:33 PM
Fuel Injector Clinic
Jun 13, 2013 08:38 PM
JusAccord
Jan 22, 2012 04:49 PM
TeamCracka
Apr 28, 2004 06:55 AM
