Zerg 2ply head gasket
Old Mar 29, 2013 | 05:09 AM
Tkymik's Avatar
10 Year Member
Default Zerg 2ply head gasket
Has anyone tried the Zerg 2 ply head gasket? Does anybody know its thickness? Thank you.
Old Mar 29, 2013 | 08:50 AM
accorse07's Avatar
Default Re: Zerg 2ply head gasket
0.47
Old Mar 29, 2013 | 09:04 AM
seelback's Avatar
im using on my b20vtec setup. i copper sprayed it and it sealed fine, i bent all the valves in the head the same week i put the head on, pulled head, put new valves in, cleaned the already used zerg head gasket, copper sprayed it again and it sealed fine again. and its been going for about 1.5-2 years with no problems. im also using arp head studs
Old Mar 29, 2013 | 03:25 PM
EsotericImage's Avatar
Retired Moderator
Originally Posted by accorse07
0.47
Damn thtas tall!
Old Mar 29, 2013 | 03:40 PM
accorse07's Avatar
Originally Posted by EsotericImage
Damn thtas tall!
That is in "mm" since we are on the subject of Thin head Gaskets...they all mostly come from Japan and such so I am used to stating them in that measurement.
It is .0185 in comparison to a stock Honda gasket which is .027?
Old Mar 29, 2013 | 04:02 PM
Tkymik's Avatar
10 Year Member
Thanks.. so that would retard the cams by 1.5 degrees?
Old Mar 29, 2013 | 08:06 PM
Retired Moderator
I use an OEM 3 layer and my crush thickness is .023 with feeler gauge
-Darren-
Jun 2, 2009 03:54 PM
eastbay925
Apr 7, 2009 09:44 AM
lilshady6796
Feb 3, 2009 07:59 PM
filetofit
Aug 13, 2002 08:49 PM
