Suspension & Brakes Theory, alignment, spring rates....
ek sedan suspension issues help!
Old Mar 28, 2013 | 06:57 PM
therainycityEK's Avatar
Icon3 ek sedan suspension issues help!
The problem is that the car is slammed in the front and about 2-3 inches above the tire in the rear and i have h&r springs im not sure why its like that and the rear is also weird ahah right side is maybe .5-1 inch higher then the left rear. strange stuff i know but would anybody know how to fix this? and no rude comments please and thank you. also could u post pictures of how your ek sedan sits on springs or just ek in general thanks!!
Old Mar 28, 2013 | 07:03 PM
grumblemarc's Avatar
The Grumpiest
Default Re: ek sedan suspension issues help!
You can't fix it. That's the problem with running lowering springs on cars this old. Should have gotten adjustable coilover sleeves.
Old Mar 30, 2013 | 07:12 AM
alphalanos's Avatar
something has to be wrong. slammed in the front and 3 inches ABOVE the tire in the back.
this is what my old civic looked like on h&r sport. im guessing you have h&r Race?
Old Mar 30, 2013 | 07:26 AM
The Grumpiest
Bushings not clocked. That's the only other thing I can think of.
Old Mar 30, 2013 | 11:51 AM
spAdam's Avatar
Loved
Community Favorite
Aftermarket bump stops? A couple months ago when I did my Konis I decided to reinstall the OE dust boots. I also initially reused the stops off of my old S2 shocks since they were in great shape. Dropped the car off the jack after putting it back together and the rear was locked up around stock height.
Turned out the S2 stops were slightly larger than the original ones and didn't quite fit in the dust boots. Put the OE ones back in and everything was fine. You might want to check there.
Old Mar 31, 2013 | 02:04 PM
NVturbo's Avatar
O.G. triple O.G.
Coils were installed backwards. Swap them. Plus, if you're on the old stock shocks, expect it to be uneven.
3rdgen3
Suspension & Brakes
Mar 10, 2009 07:52 PM
Eran
Northwest (Sales)
12
Sep 6, 2007 04:48 PM
ej6.sean
Aug 2, 2007 11:46 AM
EKidd
Suspension & Brakes
Nov 14, 2006 11:07 PM
SickWitIt2.0
Sep 30, 2005 01:32 PM
