Moisture Shield Material suggestions needed.
Old Mar 28, 2013 | 08:50 AM
belairbrian's Avatar
Default Moisture Shield Material suggestions needed.
I pulled the door panels off to adjust the glass stops only to find two broken. Well the replacements arrived today so I plan on installing them this weekend.
While I had the panels off I found one of the plastic shields missing and the other had gotten pretty stiff but useable as a pattern.
Any suggestions on what to make them from? I was thinking maybe a heavy plastic painters drop cloth. But am open to ideas from others that have done this.
Old Mar 28, 2013 | 01:27 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: Moisture Shield Material suggestions needed.
Plastic sheeting works fine. To attach it to the door, I would use thin HVAC foil tape. Go to your local Lowes, Home Depot, etc and head to the metal duct section. The tape will be metallic looking and very thin. Don't use regular duct tape.
Old Mar 28, 2013 | 03:58 PM
canadaek's Avatar
i used vapor barrier on mine and acoustic sealant (tape would be cleaner)
realmike15
Honda Civic (2001 - 2005)
Apr 4, 2011 07:49 PM
SIC-CIVIC
Feb 10, 2008 09:07 AM
Madvillian45
Audio / Security / Video
Apr 22, 2007 02:34 PM
sonicSVT
Mar 9, 2003 02:44 PM
TurboBumblBee
Oct 9, 2002 10:10 AM
