FS - gsr b18c1 part out
was going to build this block but found different block to build.
1 - b18c1 - yr. 95.
got the block and was bored out to 81.5mm would recommend either going 82mm or getting block sleeved. comes with matching main caps, only have 3 oil squirters (used one for my other motor)
the previous owner had a rod knock on the motor, has slight scoring on number 4 cylinder walls.
the threads that hold the spring for the tensioner cracked, would require to get welded and have threads repaired.
selling block for 120$
2 - i have 2 gsr cranks with each having a spun rod, both are repairable.
40$ each
3 - 6 good gsr rods 20$ per rod
4 - p72 oil pan, in good condition, will include semi new oil pickup - sold
5 - extra set of gsr main caps and girdle - 50$
6 - 1 sets of gsr cams - 40$ per set
7 - gsr crank pulley - 40$
8 -
will list more items as i go through my spare parts.
contact: text prefered 909 240 4802
1 - b18c1 - yr. 95.
40$ each
8 -
