How do you adjust the denji Projectors?
Old Oct 22, 2002 | 10:55 AM
underpressure02's Avatar
Default How do you adjust the denji Projectors?
I bought a car that came with the4 Denji projectors and my high beams are in the trees. I tried turning both of the bolts and they do not seem to move the height of the lights does anyone know how to turn the height down? TIA
Old Oct 22, 2002 | 11:25 AM
2camsaam's Avatar
Default Re: How do you adjust the denji Projectors? (underpressure (wtbimport))
I had fun doing this.
I have them in my car now. I decided to use the highbeams as my every day driving beams.
I took off the front bumper and then took out the projector housings.
One of the screws adjusts from left to right and the other adjusts up and down.
I recommend looking into the housing and looking at the screw. You can see if it is all the way screwed in or all the way out or mid-way or whatever.
Screw one all the way down and see the position of the light projected once put back on the car.
Now screw it all the way the opposite direction and see where it is projected.
Now that you know the controlls you will know how to adjust them.
I just kept adjusting the projectors and then putting them back in until I got them perfect.
Old Oct 22, 2002 | 12:45 PM
Default Re: How do you adjust the denji Projectors? (2CAMSAAM)
That is what I was thinking about doing last night. You do not rember if the one on the top turns the headlight up and down and the one on the bottom goes left to right. I turned and turned them last night and did not seem to move.
Old Oct 23, 2002 | 09:23 AM
In case any one is interested. I took them out last night and figured out which one does what. The top screw for the low and high beam move the lights to the left and the right. The bottom screws for the low and high beams move the lights up and down. They are a pain in the *** to adjust right.
Old Jan 19, 2003 | 07:03 AM
Fuster_Cluck's Avatar
Can someone look at the pics of my Denji projectors and tell me what # adjusts what? I need to raise my high beams since they sine on the ground just like the low beams...
Also, does Denji have a web site? My friend has the same exact lights and having major problems with them! Thanks!
NMZ
Dec 15, 2006 12:29 AM
fg2si!kid
Honda Civic (2001 - 2005)
Oct 28, 2006 09:33 PM
thomst4R
Jul 22, 2005 07:54 PM
curiousgpnoy
Jan 9, 2002 09:40 PM
zakiu
Aug 11, 2001 09:19 AM
