Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Header Swap (want to avoid the check engine light)
Old Mar 27, 2013 | 04:38 PM
justBrowsing's Avatar
Default Header Swap (want to avoid the check engine light)
Quick DIY write up that this guy used to avoid the check engine light.
http://www.7thgenhonda.com/forum/showthread.php?t=19006
I want to basically do what this guy did but I'm wondering about the parts list.
Can I re-use any bolts/gaskets or anything? Basically what do I really need to swap it out without having the check engine light?.
If you want to recommend a certain brand of header or anything for me that'd be cool too thanks
Old Mar 31, 2013 | 02:49 PM
toyomatt84's Avatar
Sanji
Default Re: Header Swap (want to avoid the check engine light)
You might be able to re-use the exhaust manifold gasket, but I'd advise replacing it (for a better seal). The bolts should be re-usable, and your donut should come with the new header.
Old Apr 2, 2013 | 10:09 PM
lowlife9's Avatar
usually when uou buy a new header its comes with both a new manifold gaskit and donut gaskit my megan header did. make sure you get a megan angled simulator for around 25 bucks. yor also mite need to replace the spring bolts they usually rust out the new header will probably come with bolts but i wouldn't use them use spring bolts.if your state has smog checks you mite fail the visual inspection.
the171
22
Dec 24, 2011 06:02 PM
civicsi21
Apr 23, 2005 08:01 PM
baked_beanz
Apr 21, 2005 12:29 PM
Train
Mar 13, 2004 04:35 PM
onyx00
Nov 21, 2001 09:09 PM
