Radiator replacement gurus
Old Mar 27, 2013 | 01:47 PM
Duaber's Avatar
Default Radiator replacement gurus
Hello so my cheap autozone radiator decided to spring a leak on my 1997 honda accord ex auto almost a year after replacement. The main problem I had when doing the replacement is that the motor on the cooling fan on the passenger side will hit the ac suction hose/pipe whether I had the fans attached or not. Anyone got tips on jimmying these in and out without breaking the ac line by bending it? I'm almost half tempted to buy a 12" slim fan to make things easier.
Old Mar 27, 2013 | 02:20 PM
92 civic ex 4dr's Avatar
Remove the condenser fan first then move the radiator cooling fan over into the middle. Also remove the top radiator mount bolts the move the radiator forward a little.
You can also just unbolt the fan, leave it in place and pull the radiator out leaving the fan(s) in the engine bay.
Posted from Honda-tech.com App for Android
Old Mar 27, 2013 | 02:46 PM
tdohcaccord's Avatar
Default Re: Radiator replacement gurus
unbolt the ac line bracket.. move it up and out of the way, that will give you room to pull the fan up and out.. then you can easily slide the other fan over as well..
pretty easy to do. the lower bolts just need to be loosened to remove the fans unlike the top ones that need to be removed
Old Mar 27, 2013 | 04:24 PM
holmesnmanny's Avatar
i second what 92 civic said. It's easiest to remove the condenser fan. You'll have to get the two lower bolts from underneath. I actually just remove both fans. Then it'll just slide right out. Leave the lower hose connected to the radiator til after you remove it. Just remove it from the thermostat assembly in the back. Remove the lower hose and radiator together.
Old Mar 27, 2013 | 04:30 PM
oh and the hoses.. i personally remove the lower hose from the radiator before pulling it.. that way all the coolant drains basically right at the drain plug... less mess
BongoBennie
Jan 10, 2017 06:29 PM
motegicivic
Jul 21, 2011 08:10 PM
black_bb1
Jul 17, 2006 05:33 AM
Tuesdaynightfever
Apr 4, 2005 12:30 PM
fastbrakes
Dec 28, 2002 03:52 AM
