F/S******DC2 Integra*******k-series******electric p/s********clean!!!!!!!!!!!!!!!!!!!
SOLD!!!
1996 Integra GS-R
Granada black pearl
clean title
pink slip in hand!
Engine
-2005 RSX type S "k20z1" stock longblock 90k mileage
-"k20a2" 6 speed transmission stock 4.3fd, stage 2 competition clutch & jdm itr flywheel "about 8k miles on clutch n fly"
-Karcepts 3" cold air intake w/ brand new injen filter & hydro shield
-jdm itr throttle body & sensors
-kiddracing v2 "k-swap" header
Chassis:
-brand new interstate battery
-k-swap innovative "60a" steel mounts
-hasport k-series conversion harness
-karcepts shifter mounting kit
-rsx-s shifter box and cables w/ s2k shift ****
-karcepts k-swap clutch line kit
-gates molded upper radiator hose
-hybrid racing k-series ground wiring kit
-hybrid racing k-series fuel line kit
-hybrid racing k-series fuel rail
-hybrid racing fuel pressure gauge
-aeromotive fuel pressure regulator
-walbro 255 fuel pump
-hybrid racing k-swap budget swap axles
-ep3 idler pulley & belt
-blox racing competition series traction bar
-custom 2.5in. exhaust "stainless" w/ 18in. "magnaflow" resonator from mandrelexhaustsystems.com
-2.5in. flex coupling
-OEM "denso" primary o2 sensor
-mugen twin-loop "replica" muffler "3in."
-toyota mr2 ehps pump/system from karcepts, brackets, lines, etc.. with toggle switch to turn on and off at anytime.
Interior:
-led light bulbs
-alpine s lower door and mid speakers
-stock "black" gs-r seats, dash, floor mats, cargo cover, etc. . . in great condition! with spare tire all stock nothing touched
-98 spec jdm itr red stitch boot
-MoMo tuner "320mm" steering wheel w/ nrg quick release and hub
Exterior:
-ce28n replica 16x7 wheels "silver" +40 offset with brand new westlake tires 205/45/16's
-koni "yellow" adjustable struts brand new!
-eibach "pro-kit" springs
-rolled fenders all around
-brand new cross drilled/slotted rotors, pads, fluids, etc... all around
-ddm tuning 35w "4500k" low beam hid's
-piaa turn signal bulbs
-rear led light bulbs and license plate bulbs
-rear shaved emblems
-jdm sir-g front "H" emblem "I have the rear one as well"
sorry for blurry pic. still clean though
led bulb here too
happy day!!!
all parts/ k-swap parts i bought brand new, not even 9k miles on everything.
the cars currently fine tuned with hondata "K-pro" on dynapack...
good gas mileage, great for daily driving, very reliable, nothing wrong, car drives like a champ!
tags are good till june 2014
i just recently replaced the clutch master cylinder with a brand new oem cmc. flushed the clutch fluid and refilled with dot3/ dot4 friendly Motul Racing 5.1 fluid.
replaced timing chain tensioner with brand new oem tensioner.
changed oil, always Mobile1 GOLD seal full synthetic 5w-30 with oem honda oil filter.
$9000 obo
i can go lower on price depending on what you want or dont want
i put nearly $15k into this car. my loss your gain!
call/text @8585041006 or pm me with offers if very interested and for more info or questions as well
thank you
ps. possibly trade for rsx-s...
1996 Integra GS-R
Granada black pearl
clean title
pink slip in hand!
Engine
Chassis:
Interior:
-led light bulbs
Exterior:
led bulb here too
happy day!!!
$9000 obo
thank you
dang 244 on a stock z1? i wish my b18b1 would make 200hp stock
this was with pwjdm intake, before i upgraded to karcepts 3in. cai.
when i switched intakes the cai gave me 9 more hp and a couple tq..
you can ask todd @church automotive testings, he could vouch
Churchs dyno reads way high its impossible to make 244 on a stock z1 with that shitty manifold..I had a2,z1,and now on a frank k20/k24 setup and my z1 had a rbc and rcrew header and made 228hp at go power motorsports the motor comes stock 210hp kpro isn't gonna pull out 34hp just on a stock tune..
very belivable hp
my friend dyned at church 263 whp and 184lbs torque with his k20a2 with k20z1(itr cams), kidd racing header, ac and p/s, full 3 inch custom asc exhaust, custom asc 3-3.5 inch cold air intake with velocity stack, hondata kpro, hondata intake gasket, and cut open and ported rbc and port matched to the skunk2 74mm throttle body.
very belivable hp
very belivable hp
that makes 100% total understanding why your saying its higher in reads
do the math bro!
which means my car is like 224hp "to the wheels and not hub" which is good numbers from a z1 with bolt-ons i would say..
Sure is good numbers..I'm not hating on your build I'm all for k series I'm on my 5th k car ill never dip a bseries again..some people might see this post and think if they put in a stock z1 they are gonna be almost 250 to the wheels... Glws by the way
