brake bleeding
ok so I have a 94 integra gsr I did a brake tuck used the rywire brake tuck kit 40/40 prop valve rs master cylinder and booster but cannot get the passenger brakes to get pressure any help would be realty appreciated
did you make sure everything is hooked up where its suppose to be? make sure nothing is leaking? are you using the OEM rubber lines to the caliper? if so, might have colapsed
have checked for leaks no leaks double checked all lines on the prop valve over and over again and yes using the oem soft lines to the caliper but when I crack the front line of the mc there is no fluid there.....the mc was bench bled I am out of ideas
