FL 66mm Borg s366xl Integra Custom Top mount AC and PS HIGH HP....
Please read the entire post before making a cash/trade offer.
This car is in exceptional shape. Interior looks brand new. Brand new carpet installed and floor mats.
Paint is fairly new and shines great
CAR IS TUNED ON BOTH PUMP GAS AND Q16
Cash price: 12k or trade. Any reasonable trade will be entertained
Car has freezing cold ac. Car has custom ac lines that where made at Amazon in tampa
Car also had great working power steering and cruise control. all the creature comforts you would want in a car.
This isnt your average teenagers honda. The car makes a lot of power and i rather it go to someone that is mature enough to handle it.
Entire turbo kit was made at 1320 Engineering in Tampa. Turbo parts for Turbo kit was purchased at BOOSTLAB in tampa
I dont mind keeping the car. Im not in need of cash nor another car. Please use you head before offering a car for trade or a cash offer.
Car: 1999 Acura Integra Gs
Miles: Car has 81k original miles/ Motor only has 2k miles since rebuild/ Turbo kit has less than 100 miles
Exterior: Fresh Vsm paint job. NO bs paint job. It looks 100x better in person. I'm picky and don't accept anything less than perfect. Oem Jdm Itr front. Jdm Itr headlights are in new condition. Edm clear side markers.
Interior: Carpet is in brand new condition. Gsr leather back seats. Rsx front seats. Gsr cluster.
Suspension: H&R race springs and tokico whites. car rides like stock. Oem usdm itr 5 lug conversion. All new bearing, ball joints and disk and pads. Also has rare EDM itr 16'' gunmetal stocks
Motor:
Block
1995 b18b1 block sleeved with darton sleeves
84mm 9:1 weisco roller pistions
eagle H-beams
golden eagle gsr spec crank
golden eagle gsr girdle
acl race bearing and thrust washer
Competition Clutch twin disk clutch and flywheel
Arp 1/4'' head studs
Head:
1997 Gsr head
Mild port job
VictorX intake manifold. Port matched to the the head (JET COATED )
Hondata intake manifold gasket
Aem Fuel rail
Fuel injector clinic 1100cc injectors
crower 1mm over-sized valves
crower dual valve springs
crower titanium retainers
crower cams BC0021
skunk2 cam gears
Blox 70mm tb
GM 3 bar map sensor
Itr valve cover
password jdm cam seal
areomotive a1000 fuel pressure reg
full fuel system changed to AN fittings
Walbro 450lph fuel pump
Trans:
99 gsr trans. legit. Vin plate attached.
Syncrotech syncros 1-4th gear
oem lsd
Turbo kit: Every part was bought brand new and has less than 100mile in it
Borg Warner s366xl T4 twin scroll ( jet coated the hotside )
Twin Scoll Top mount custom ac/ps compatible manifold made of sch11 by 1320 engineering
3'' intercooler pipping both hot and cold side
3'' down pipe to a dump
Greddy 3'' Intercooler
Turbosmart 45mm wastegate
Tial 50mm BOV
Electronics:
Aem Wideband
Greddy Profec 2 electronic boost controller
Apexi Turbo Timer
GM 3 Bar map sensor
Hondata s300
Copy and paste this link for dyno vid
Motor:
Block
eagle H-beams
Head:
1997 Gsr head
Mild port job
Aem Fuel rail
crower cams BC0021
skunk2 cam gears
Blox 70mm tb
GM 3 bar map sensor
Itr valve cover
Trans:
oem lsd
Tial 50mm BOV
Electronics:
Aem Wideband
Apexi Turbo Timer
GM 3 Bar map sensor
Hondata s300
wannabe_itr
Mar 29, 2013 06:36 PM
legomytego
Jan 12, 2009 01:29 PM
