1997 honda civic hatch b16a3 bogging on acceleration
Old Mar 26, 2013 | 11:13 AM
ehansford22's Avatar
Default 1997 honda civic hatch b16a3 bogging on acceleration
Ok so I've searched and got no direct answer to my problem. I am having an issue with bogging while accelerating. Do not know what rpm because I have no tach. But after a certain rpm it accelerates normally. I had a hacked up harness which I though was the problem. Just replaced it yesterday. Did the ckf trick and wired in my secondary o2 simulator. No codes. I have ran a p72 GSR Ecu. A p73 Ecu. And a p2p single v Ecu. They all have the bogging under certain rpm. I've seen that it could be timing but here's the weird part. When I throw in my chipped obd1 Ecu. (Do not know what's on it but it runs the car perfectly along with no cel) so it couldn't be timing. Before I changed my harness I was getting codes of p0130 and 131. All low voltage problems. I am stumped. Any knowledge from h-t would be greatly appreciated.
1997 honda civic hatchback dx
Obd2a ex vtec harness
Motor info-b16a3. Stock internals. B16 tranny. I/h/e. fuel rail. Fpr set at 40 psi.
New-dizzy, harness
Please help lol
Old Mar 26, 2013 | 11:16 AM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
Default Re: 1997 honda civic hatch b16a3 bogging on acceleration
so the wrong ECUs run it shitty, but the chipped one which may be running the right map is running it fine?
Old Mar 26, 2013 | 11:19 AM
Yes. All of the ecus that are obd2 make it bog but with the chipped obd1 it accelerates phenomenal. Not problems at all
Old Mar 26, 2013 | 11:21 AM
doctorake's Avatar
Community Builder
Find out what is on the obd1 ECU or get the right ECU for the motor.
Old Mar 26, 2013 | 11:27 AM
Emeraldbomber's Avatar
^ 2nd
Old Mar 26, 2013 | 11:30 AM
Anyone else having similar issues. Any other advice at all? Thanks for the advice doctorake. Have been diagnosing this problem for 4 months now
Old Mar 26, 2013 | 03:13 PM
eghatch9295's Avatar
Stancetard Hate Monger
doesnt sound like much of a problem if the correct ecu/basemap makes the car run right. since it is essentially a b16a2, you could always run an em1 ecu.
Old Mar 26, 2013 | 04:13 PM
doctorake's Avatar
Community Builder
obd2 P30 would be the correct ECU since the Chassis has no FTP sensor.
Old Mar 26, 2013 | 05:08 PM
Update. I did the ckf trick but doesn't seem to be working correctly with the ckf c1 and c11 pins in or if I got a code 9 which I think is p1337 which means to depin c1 and c11. p1337 is for the cyp sensor correct? Should I try de-pinning c1 and c11 again and see how it goes. I'm thinking of this because obd1 doesn't look for it right. That's why my obd1 Ecu runs my car so perfectly?
I know all about the correct Ecu to run. Can't seem to get my hands on a obd2a p30. Also my car is a 97. If I run a 2000 si Ecu which is 130 dollar jumper harness it will look for the FTP sensor which my car isn't equipped with so there's a cel I deff don't need!
Thanks for all the input guys
Old Mar 27, 2013 | 04:31 PM
89CivicDXGuy's Avatar
Check your cat converter.
Old Mar 27, 2013 | 04:44 PM
Hi flow cat! I'm puzzled on this. Really don't get how this hasn't happened to anyone else. Got over 150+ views and got 4 replies on a Ecu which all of the Ecus ran my car fine except for the low range accel
Old Mar 28, 2013 | 06:10 AM
Originally Posted by crazyhouse2011
Remove your catalytic converter and run the engine for 15 minutes without it, then take it for a drive to see what happens. Put it back on when you are done, let it run 15 minutes, and take it for another drive. Compare results.
Is this safe running open header? But This all boils down to something wrong with the ckf wire trick. I have my p2p running. I Like where vtec is at. But It will bog and I'm getting code p1337.
Old Mar 28, 2013 | 10:45 AM
Turns out my pins for c1 and c4, c11 and c14 are not touching my Ecu pins properly or at least one of them. Anyone ever have this problem. Is there a solution to this. Am going to search a little. Just thought I'd share my almost fixed problem!
Old Mar 28, 2013 | 10:59 AM
doctorake's Avatar
Community Builder
Did you run open headers?
Sounds like it was his ECU not a cat.
Old Mar 28, 2013 | 11:04 AM
doctorake's Avatar
Community Builder
I thought it woulda been funny if he did, because 1) it would sound like complete **** going down the road (especially if he's autobox) and 2) it's illegal. But his choice of course!
So you are giving out stupid advice trying to troll members?
Old Mar 28, 2013 | 11:05 AM
crazyhouse2011's Avatar
Nope. I've done it before it my car. It was quite fun. Pain in the *** to get the exhaust back on though.
Old Mar 28, 2013 | 11:22 AM
grumblemarc's Avatar
The Grumpiest
WTF do open headers have to do with the fact that the OP has a contact issue with the pins on his ECU?
Old Mar 28, 2013 | 11:25 AM
Word thanks dick. I didn't take your advice seeing that your ignorant anyways. How's a brand new cat gonna be bad in the first place. Second this post is about an Ecu problem. Why would I try some dump sh** from a person like you. Any ways back to real people on h-t. I'm having trouble with these wires. I'm now throwing p1382 and will bounce back to p1337. I believe it's a wiring/Ecu pin issues.
Old Mar 28, 2013 | 11:27 AM
The Grumpiest
Have you tried simply pushing on the pins at the connector to see if they reseat?
HAHAHAHA. What a day....
Reported. I think people have had enough of you.
Old Mar 28, 2013 | 11:31 AM
Yes I just had it running perfectly before. Once I moved my Ecu it bounced right back to code p1337. I've depinned connector c about 2 or 3 times thinking that if I were to remove c1 and c11 the cel would go off but all I got was code 9 so I put them back in!
JuggerNaut-CTR's Avatar
I believe you are right...
Why do you keep following me around? Go away!
I wish you would sign off and never come back....
Old Mar 28, 2013 | 02:55 PM
It Wasn't Me's Avatar
Troll banned for 30 days. If they continue trolling upon return, don't hesitate to report it.
Old Mar 28, 2013 | 07:40 PM
Thanks so much!
Old Mar 29, 2013 | 04:45 AM
doctorake's Avatar
Community Builder
Did you find out what was on the OBD1 ECU?
Old Mar 29, 2013 | 10:21 AM
No don't have a tuner or anyone who messes with chips. It comes down to the wiring for the ckf and cyp. I'm attempting to do the ckf trick. Harness is all hacked up again. Back to step 1 again. Coming down to just selling it. Been nothing but headaches with just this sensor for 4 months now. Kind of ridiculous. When I splice them together I get p1337 still. If I mess with the wires I get p1382 code 9 so I remove c1 and c11 and it goes right back to code p1337. CLUELESS
