1993 accord auto tran
Old Mar 26, 2013 | 06:26 AM
krazzy1999's Avatar
Default 1993 accord auto tran
my car is not shifting when it is supposed to . I changed fluid it helped some but it still not shifting when it is supposed to. it is shifting at or above 4000 rpm, and you have to let up on the gas for it to shift
Old Mar 26, 2013 | 10:46 AM
NZXTInerTia's Avatar
Default Re: 1993 accord auto tran
Getting worn out, how many miles are on it? You could also try cleaning the shift solenoids for debris.
Old Mar 26, 2013 | 08:55 PM
krazzy1999's Avatar
280,000 miles it is supposed to be a newer train
Old Mar 26, 2013 | 09:38 PM
Like I said, clean the shift solenoids.
http://tl.acurazine.com/forums/showthread.php?t=644943
Old Mar 27, 2013 | 03:48 AM
MAD_MIKE's Avatar
MM Gruppe B
Have you checked for codes? A code may have been stored, do not unhook the battery to 'clear' the check engine light. Retrieve the code first.
Verify that your TPS has a linear change in voltage, and again check the carbon tracking with the TPS unplugged with an Ohm meter. If the TPS is worn it can cause erratic or no shift events.
Verify that all electrical connectors are not broken/damaged/corroded.
If the shifting is harsh check the NM shaft sensor.
If lockup does not occur check the NC sensor.
TCU may have a faulty capacitor and/or resistors.
For trouble shooting go to: http://techauto.awardspace.com/transmission.html
badfish74
Aug 7, 2025 06:47 PM
astrochimp
Dec 6, 2018 06:38 AM
bades
Transmission & Drivetrain
Jun 5, 2010 07:45 AM
00Accord03Odyssey
Jan 22, 2009 06:30 PM
v.i.gsr
Nov 8, 2006 06:57 PM
