Suspension & Brakes Theory, alignment, spring rates....
Popping suspension
Old Mar 25, 2013 | 03:28 PM
CD5B2's Avatar
Icon3 Popping suspension
'97 accord w/ koni orange and eibach pro kit. Made this popping sound ever since the day I had it lowered. Spring isolators, sway bar bushings and endlinks replaced. Anyone have a clue what could cause this sound?
Here's a video of the dreaded sound. It makes the same sound when I'm driving but goes away at higher speeds.
http://www.youtube.com/watch?v=DM0JK...ature=youtu.be
Old Mar 26, 2013 | 01:20 AM
808zrk's Avatar
Default Re: Popping suspension
hmmm, you cant isolate the sound coming from a specific area? When my car was really low the uca banging on the shock tower made a similar sound.
Easiest way would be have your friend bounce your car while you try and locate where the noise is coming from
Old Mar 26, 2013 | 04:22 PM
CD5B2's Avatar
Yeah I got someone to push down while I listened. Sounds like it's coming from the top of the assembly. My car isn't that low, so I don't think it's hitting the uca. I'm thinking maybe the mount?
Old Mar 27, 2013 | 10:42 AM
Crazed_GSR's Avatar
From the looks of the video, your driver side top mount seems to have some free play in it while you were bouncing the car. Double check that.
Old Mar 28, 2013 | 10:25 PM
CD5B2's Avatar
So just replace the upper and lower mounts?? I just wanted to make sure that's what it is before I buy the part(s) and get my mechanic to install them. I don't have a spring compressor or an impact gun so I can't do it myself.
Old Apr 4, 2013 | 01:33 AM
808zrk's Avatar
Don't go blindly buying parts, why don't you remove the wheel and check the wheel well?
Old Apr 25, 2013 | 05:00 PM
CD5B2's Avatar
Update: It's fixed :D The pestering sound is gone!!! I got moog upper and lower rubber strut mounts with the washers put in. Also got energy suspension sway bar endlinks put in. They make a huge difference in cornering stability.
CD5B2
Mar 27, 2013 10:38 PM
vtec2K9
Jul 23, 2009 11:26 AM
BigChris
Mar 17, 2003 09:24 AM
PearlWhiteAccord
Oct 15, 2002 05:27 AM
GettaluvR
Sep 27, 2001 03:08 PM
