Suspension & Brakes Theory, alignment, spring rates....
92-95 Front UCAs on 5th gen. Why not?
Old Mar 25, 2013 | 11:03 AM
grumblemarc's Avatar
The Grumpiest
Default 92-95 Front UCAs on 5th gen. Why not?
Got a question that's been bugging me. On my 6th gen Civic there looks to be provisions (the two black plugs/grommets on either shock tower) for UCA mounting similar to the 5th gen Civic. So can you use these to actually mount 5th gen style UCAs or is there something other that prevents that? Mind you I don't own a 5th gen Civic and haven't for a long time nor do I have 5th gen Civic hardware to try out. Just curious what these points are for on the 6th gen is all.
Old Mar 25, 2013 | 11:11 AM
The Grumpiest
Default Re: 92-95 Front UCAs on 5th gen. Why not?
Looking a little closer via a Google image search, those aren't even the mounting points for UCAs so WTF are those holes for?
Old Mar 25, 2013 | 11:17 AM
The Grumpiest
Okay now I'mm all messed up. The 5th gens have those grommets/plugs as well but it looks like in a slightly offset location. I've never seen anything installed there for either generation.
Old Mar 25, 2013 | 04:28 PM
phunhaus's Avatar
The inner bracket for the stock 6th gen front upper control arms would prevent this from being possible.
As far as I can tell changes to the 96-00 chassis over the 92-95 are upgrades. The change in length for the rear LCA, the mounting style of the front UCA and the redesign of the front LCA and sway bars should benefits. I wouldn't personally go to anything from the EG chassis even if it was possible.
Old Mar 25, 2013 | 04:36 PM
The Grumpiest
So what are those mounting points all about? What are they even used for? Again, just curious.
Old Mar 25, 2013 | 07:06 PM
98civdx's Avatar
Master Detailer
i always wondered what they are for, but those holes are where my Neuspeed strut bar bolted to.
Old Mar 25, 2013 | 09:13 PM
phunhaus's Avatar
You'd have to ask a vehicle engineer for the purpose of those holes. It could be for something as simple as manufacturing.
Halo
Jan 22, 2006 02:34 PM
azian21485
Feb 13, 2005 03:13 PM
C-Zero
Jan 25, 2004 03:58 PM
Fly1865
Sep 21, 2002 02:21 PM
Lookincrazy
Jan 4, 2002 12:23 PM
