98 civic O2 senser questions
Old Mar 25, 2013 | 09:56 AM
Genesis0863's Avatar
Default 98 civic O2 senser questions
ok keep getting a rich code on my civic. As far as the car running it runs great i just keep getting rich codes and it does run rich at idle. I replaced both o2 sensors but i think i got the wrong one for the downstream sensor. So here are the specs on my car it is a 98 civic DX with a d16y8 swap. now car still has the DX Ecu in it. I have heard that the upstream and downstream o2 sensors are the same but i bought 2 different ones.. If anyone has the part numbers i need for the right o2 sensors that would be cool.
Old Mar 25, 2013 | 10:03 AM
goldsy's Avatar
Default Re: 98 civic O2 senser questions
I believe both o2 sensors are the same. The Denso o2 sensor which is what they came out of the factory with is 234-4099
Bleakened's Avatar
Both the o2 sensors are indeed the same as I have recently replaced both of mine. Where did you get the o2's at? I would return them and get some from Autozone if possible as they can get you exactly what you need without any guessing. That's what I'd do anyway.
What are you driving btw, coupe or hatch?
Old Mar 25, 2013 | 11:29 AM
i got them off rockauto. i think i got one right but the other is wrong so hopefully i only need to order one. but i drive a coupe. i have a few pix up on my profile i think.
AGENT 99
Mar 5, 2006 09:46 AM
Shakes
Apr 28, 2004 08:45 PM
Qwikrex
Jul 31, 2002 09:53 PM
